Lenovo ThinkPad X390 Fan Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
22
Past 30 Days:
114
All Time:
2,090
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
If you need to replace your laptop’s fan please refer to this guide. Exercise caution before beginning this guide by ensuring that the laptop is unplugged and turned off. To complete the replacement of your fan, you will need a plastic opening tool, a #0 Philips head screw driver, and a pair of tweezers.
Parts
Tools
    1. Lenovo ThinkPad X390 Fan Replacement, Back Cover: step 1, image 1 of 1
      • Turn off and power down the laptop before proceeding with the guide.
      • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
      • Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
      • The screws are not removable.
      Ask FixBot
    2. Lenovo ThinkPad X390 Fan Replacement: step 2, image 1 of 2 Lenovo ThinkPad X390 Fan Replacement: step 2, image 2 of 2
      • Remove the base cover by inserting a plastic opening tool in between the cover and the rest of the laptop.
      • Once the tool is inserted, slide the tool along the edges of the case and push down on the opening tool to detach the case.
      • You may need to move the tool to different locations to fully release the back cover.
      Ask FixBot
    1. Lenovo ThinkPad X390 Fan Replacement, Fan: step 3, image 1 of 1
      • Unplug the fan connector from the motherboard.
      Ask FixBot
    2. Lenovo ThinkPad X390 Fan Replacement: step 4, image 1 of 1
      • Using the Phillips #0 screwdriver, unscrew the four screws holding the heat sink to the motherboard.
      Ask FixBot
    3. Lenovo ThinkPad X390 Fan Replacement: step 5, image 1 of 1
      • Lift the fan up and out and remove it from the device.
      Ask FixBot
2 other people completed this guide.
Nick Couch
273 Reputation
1 Guide authored
Clemson, Team 5-1, Hunter Fall 2021 Member of Clemson, Team 5-1, Hunter Fall 2021
CLEM-HUNTER-F21S5G1
5 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 22
Past 30 Days: 114
All Time: 2,090
