Lenovo ThinkPad X390 Battery Replacement
    1. Lenovo ThinkPad X390 Battery Replacement, Back Cover: step 1, image 1 of 1
      • Turn off and power down the laptop before proceeding with the guide.
      • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
      • Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
      • The screws are not removable.
      Ask FixBot
    2. Lenovo ThinkPad X390 Battery Replacement: step 2, image 1 of 2 Lenovo ThinkPad X390 Battery Replacement: step 2, image 2 of 2
      • Remove the base cover by inserting a plastic opening tool in between the cover and the rest of the laptop.
      • Once the tool is inserted, slide the tool along the edges of the case and push down on the opening tool to detach the case.
      • You may need to move the tool to different locations to fully release the back cover.
      Ask FixBot
    1. Lenovo ThinkPad X390 Battery Replacement, Battery: step 3, image 1 of 2 Lenovo ThinkPad X390 Battery Replacement, Battery: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, unplug the battery from the laptops motherboard by pulling on the cable that attaches it.
      Ask FixBot
    2. Lenovo ThinkPad X390 Battery Replacement: step 4, image 1 of 2 Lenovo ThinkPad X390 Battery Replacement: step 4, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the four 5.2 mm screws holding the battery in place.
      Ask FixBot
    3. Lenovo ThinkPad X390 Battery Replacement: step 5, image 1 of 2 Lenovo ThinkPad X390 Battery Replacement: step 5, image 2 of 2
      • Using your hands, remove the battery from the laptop.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
4 other people completed this guide.
Curtis Kubacka
310 Reputation
2 Guides authored
Clemson, Team 5-1, Hunter Fall 2021 Member of Clemson, Team 5-1, Hunter Fall 2021
CLEM-HUNTER-F21S5G1
5 Members
48 Guides authored
2 Guide Comments
Ich habe diesen Lenovo Thinkpad, jedoch einen ganz anderen Anschlußstecker des Akkus und keine Ahnung, wie ich den vom Rechner trennen kann.
Michael - Reply Share
What a blast from the past, thinking about tinkering with electronics! I used to love taking things apart. Lately, I've been hooked on Heardle as a fun music challenge, mostly because it's so satisfying to test my song recognition skills from just that first little snippet. It brings back so many memories. Do you have any specific tools you swear by for delicate repairs like battery replacements?
Jasper Hook - Reply Share
Past 24 Hours: 7
Past 7 Days: 56
Past 30 Days: 206
All Time: 10,696
