Lenovo ThinkPad X280 Wi-Fi Card Replacement
    1. Lenovo ThinkPad X280 Wi-Fi Card Replacement, Back Panel: step 1, image 1 of 1
      • To begin, ensure that the device is completely powered off and not connected to an energy supply.
      • Close the device and flip it over to expose the back panel.
      Ask FixBot
    2. Lenovo ThinkPad X280 Wi-Fi Card Replacement: step 2, image 1 of 2 Lenovo ThinkPad X280 Wi-Fi Card Replacement: step 2, image 2 of 2
      • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
      • These are captive screws and do not come out completely.
      Ask FixBot
    3. Lenovo ThinkPad X280 Wi-Fi Card Replacement: step 3, image 1 of 2 Lenovo ThinkPad X280 Wi-Fi Card Replacement: step 3, image 2 of 2
      • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
      • Remove the back cover.
      Ask FixBot
    1. Lenovo ThinkPad X280 Wi-Fi Card Replacement, Wi-Fi Card: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to gently disconnect the two wires that are connected to the Wi-Fi card.
      • They should pop off with minimal force.
      Ask FixBot
    2. Lenovo ThinkPad X280 Wi-Fi Card Replacement: step 5, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the single screw that secures the Wi-Fi card.
      • Be careful not to over-tighten the screw when reassembling, should be thumb tight
      Ask FixBot
    3. Lenovo ThinkPad X280 Wi-Fi Card Replacement: step 6, image 1 of 1
      • Use tweezers or your fingers to gently pull the Wi-Fi card from its port.
      • Pull directly away from the port, parallel with the card. Do not pull up towards yourself.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 57
All Time: 2,276
