Lenovo ThinkPad X280 Touch Pad Replacement
    1. Lenovo ThinkPad X280 Touch Pad Replacement, Back Panel: step 1, image 1 of 1
      • To begin, ensure that the device is completely powered off and not connected to an energy supply.
      • Close the device and flip it over to expose the back panel.
      Ask FixBot
    2. Lenovo ThinkPad X280 Touch Pad Replacement: step 2, image 1 of 2 Lenovo ThinkPad X280 Touch Pad Replacement: step 2, image 2 of 2
      • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
      • These are captive screws and do not come out completely.
      Ask FixBot
    3. Lenovo ThinkPad X280 Touch Pad Replacement: step 3, image 1 of 2 Lenovo ThinkPad X280 Touch Pad Replacement: step 3, image 2 of 2
      • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
      • Remove the back cover.
      Ask FixBot
    1. Lenovo ThinkPad X280 Touch Pad Replacement, Battery: step 4, image 1 of 3 Lenovo ThinkPad X280 Touch Pad Replacement, Battery: step 4, image 2 of 3 Lenovo ThinkPad X280 Touch Pad Replacement, Battery: step 4, image 3 of 3
      • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
      • Remove the battery.
      Ask FixBot
    1. Lenovo ThinkPad X280 Touch Pad Replacement, Touch Pad: step 5, image 1 of 2 Lenovo ThinkPad X280 Touch Pad Replacement, Touch Pad: step 5, image 2 of 2
      • Carefully peel off the black tape covering the touchpad connector with your fingers.
      • Use tweezers if you're having trouble gripping the tape.
      Ask FixBot
    2. Lenovo ThinkPad X280 Touch Pad Replacement: step 6, image 1 of 2 Lenovo ThinkPad X280 Touch Pad Replacement: step 6, image 2 of 2
      • Using a spudger, lift the small latch on the cable connector, then slide the cable out carefully to disconnect it.
      • In the second photo, the connector broke off. Gently pull the ribbon cable out of its socket.
      Ask FixBot
    3. Lenovo ThinkPad X280 Touch Pad Replacement: step 7, image 1 of 1
      • Remove the four 3.4 mm Phillips #0 screws that secure the touchpad.
      • With a tweezer or your hands, carefully remove any adhesive/tape securing the touchpad in place.
      • You may need to gently pry the touchpad free with a spudger.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Ruth O
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 64
All Time: 1,019
