Lenovo ThinkPad X280 Power Jack Replacement
  1. Lenovo ThinkPad X280 Power Jack Replacement, Back Panel: step 1, image 1 of 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
    Ask FixBot
  2. Lenovo ThinkPad X280 Power Jack Replacement: step 2, image 1 of 2 Lenovo ThinkPad X280 Power Jack Replacement: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
    Ask FixBot
  3. Lenovo ThinkPad X280 Power Jack Replacement: step 3, image 1 of 2 Lenovo ThinkPad X280 Power Jack Replacement: step 3, image 2 of 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
    Ask FixBot
  4. Lenovo ThinkPad X280 Power Jack Replacement, Battery: step 4, image 1 of 3 Lenovo ThinkPad X280 Power Jack Replacement, Battery: step 4, image 2 of 3 Lenovo ThinkPad X280 Power Jack Replacement, Battery: step 4, image 3 of 3
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
    Ask FixBot
  5. Lenovo ThinkPad X280 Power Jack Replacement, Power Jack: step 5, image 1 of 2 Lenovo ThinkPad X280 Power Jack Replacement, Power Jack: step 5, image 2 of 2
    • Disconnect all six ribbon cables connected to the motherboard by gently with a screwdriver or your fingers.
    • Flip up the locking flaps before disconnecting the cables where pertinent.
    Ask FixBot
  6. Lenovo ThinkPad X280 Power Jack Replacement: step 6, image 1 of 2 Lenovo ThinkPad X280 Power Jack Replacement: step 6, image 2 of 2
    • Remove the two 5.4 mm screws securing the metal bracket with a Phillips #1 screwdriver.
    Ask FixBot
  7. Lenovo ThinkPad X280 Power Jack Replacement: step 7, image 1 of 2 Lenovo ThinkPad X280 Power Jack Replacement: step 7, image 2 of 2
    • Remove the two 5.4 mm screws securing the plastic bracket with a Phillips #1 screwdriver.
    Ask FixBot
  8. Lenovo ThinkPad X280 Power Jack Replacement: step 8, image 1 of 2 Lenovo ThinkPad X280 Power Jack Replacement: step 8, image 2 of 2
    • Remove all fifteen 3.4 mm screws securing the motherboard with a Phillips #1 screwdriver.
    Ask FixBot
  9. Lenovo ThinkPad X280 Power Jack Replacement: step 9, image 1 of 3 Lenovo ThinkPad X280 Power Jack Replacement: step 9, image 2 of 3 Lenovo ThinkPad X280 Power Jack Replacement: step 9, image 3 of 3
    • Lift out the mother board to access the power jack to replace it with a new one.
    • The power jack will have to be desoldered and then the replacement resoldered. Check out this handy guide to help guide you.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 42
All Time: 646
