Lenovo ThinkPad X280 Fan Assembly Replacement
Views: 4.5K
View statistics:
Past 24 Hours:
6
Past 7 Days:
32
Past 30 Days:
139
All Time:
4,466
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 50 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This replacement guide will inform users about how to remove the fan assembly on the Lenovo Thinkpad X280.
The fan cools down the computer and prevents it from overheating.
It is important to note that your device may shut down and provide an error message to allow your device to come to an appropriate temperature. In the case that your device’s fan does not cool down to an appropriate temperature, your device will eventually be too hot and potentially spark a fire. A fried or burned area in the surrounding parts of the your device’s fan can also limit the function of the overall computer.
If your devices’s fan has dust in it and get clogged, your fan is making more noise than usual, and/or your device is hot to the touch, it might a result of an insufficient fan and fail to cool your device.
For an additional information use this resource.
Parts
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. Lenovo ThinkPad X280 Fan Assembly Replacement, Back Panel: step 1, image 1 of 1
      • To begin, ensure that the device is completely powered off and not connected to an energy supply.
      • Close the device and flip it over to expose the back panel.
      Ask FixBot
    2. Lenovo ThinkPad X280 Fan Assembly Replacement: step 2, image 1 of 2 Lenovo ThinkPad X280 Fan Assembly Replacement: step 2, image 2 of 2
      • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
      • These are captive screws and do not come out completely.
      Ask FixBot
    3. Lenovo ThinkPad X280 Fan Assembly Replacement: step 3, image 1 of 2 Lenovo ThinkPad X280 Fan Assembly Replacement: step 3, image 2 of 2
      • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
      • Remove the back cover.
      Ask FixBot
    1. Lenovo ThinkPad X280 Fan Assembly Replacement, Fan Assembly: step 4, image 1 of 2 Lenovo ThinkPad X280 Fan Assembly Replacement, Fan Assembly: step 4, image 2 of 2
      • Using the Phillips #1 screwdriver, loosen the four captive screws attached to the heat sink until a small pop sound heard.
      • The screws do not come all the way out and remain partially attached to the heat sink.
      Ask FixBot
    2. Lenovo ThinkPad X280 Fan Assembly Replacement: step 5, image 1 of 2 Lenovo ThinkPad X280 Fan Assembly Replacement: step 5, image 2 of 2
      • Using the black spudger, gently push out the gray plastic connecter from the plug.
      Ask FixBot
    3. Lenovo ThinkPad X280 Fan Assembly Replacement: step 6, image 1 of 1
      • Loosen and remove the fan.
      Ask FixBot
5 other people completed this guide.
Jordan Wooten
636 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 32
Past 30 Days: 139
All Time: 4,466
