Lenovo ThinkPad X280 Battery Replacement
Views: 12K
View statistics:
Past 24 Hours:
10
Past 7 Days:
55
Past 30 Days:
192
All Time:
12,242
Comments: 2
2 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 35 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This replacement guide will inform users how to properly remove the battery, located on the bottom center of the Lenovo ThinkPad X280 inside the back panel of the device.
The battery is used to power on and off the device.
If you are experiencing poor battery life, a battery overheating, and/or an inability to connect to Bluetooth or WIFI networks, your device may need a battery replacement.
Removing the battery will completely shut down the device and prevent it from working properly. It is important to note that removing a battery while it’s too hot can induce injury or spark a flame. To prevent injury, allow your device to cool down before removing the battery from the device and store it in an appropriate place. For more information on how to store it, you can review this guide.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
  • Spudger
    4.9
  • Phillips #1 Screwdriver
    5
    1. Lenovo ThinkPad X280 Battery Replacement, Back Panel: step 1, image 1 of 1
      • To begin, ensure that the device is completely powered off and not connected to an energy supply.
      • Close the device and flip it over to expose the back panel.
      Ask FixBot
    2. Lenovo ThinkPad X280 Battery Replacement: step 2, image 1 of 2 Lenovo ThinkPad X280 Battery Replacement: step 2, image 2 of 2
      • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
      • These are captive screws and do not come out completely.
      Ask FixBot
    3. Lenovo ThinkPad X280 Battery Replacement: step 3, image 1 of 2 Lenovo ThinkPad X280 Battery Replacement: step 3, image 2 of 2
      • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
      • Remove the back cover.
      Ask FixBot
    1. Lenovo ThinkPad X280 Battery Replacement, Battery: step 4, image 1 of 3 Lenovo ThinkPad X280 Battery Replacement, Battery: step 4, image 2 of 3 Lenovo ThinkPad X280 Battery Replacement, Battery: step 4, image 3 of 3
      • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
      • Remove the battery.
      Ask FixBot
9 other people completed this guide.
Haley Curry
572 Reputation
2 Guides authored
2 Guide Comments
but what about the batteries connection to the mobo?
edit: nvm, i assumed it was a cable not just a connector
Matthew Gould - Reply Share
I'll chime in with Matthew Gould:
The last step, "Remove the battery", could stand expansion. It took me some time to figure out that the edge of the battery with the connector simply lifts up rather than sliding out toward the user (fixer? repairer?). One more picture showing that action would help.
The rest of the process, including purchasing the battery from ifixit, was like butter.
Having said that, I am so thankful for ifixit!
Andrew Rinehart - Reply Share
Past 24 Hours: 10
Past 7 Days: 55
Past 30 Days: 192
All Time: 12,242
