Lenovo ThinkPad X270 External Battery Replacement
Views: 2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
35
Past 30 Days:
126
All Time:
1,965
Comments: 1
1 comment on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Very easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace a dead or malfunctioning external battery on your Lenovo ThinkPad X270 laptop.
If you're unsure about the health of your battery, test it using Lenovo Diagnostics.
If your battery is swollen, take appropriate precautions.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
    1. Lenovo ThinkPad X270 External Battery Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Lenovo ThinkPad X270 External Battery Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
      • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables and fully shut down your laptop.
      Ask FixBot
    1. Lenovo ThinkPad X270 External Battery Replacement, Battery information: step 2, image 1 of 2 Lenovo ThinkPad X270 External Battery Replacement, Battery information: step 2, image 2 of 2
      • Lay your laptop upside down to access the external battery.
      • Two sliding tabs secure the battery.
      Ask FixBot
    2. Lenovo ThinkPad X270 External Battery Replacement, Release the left tab: step 3, image 1 of 2 Lenovo ThinkPad X270 External Battery Replacement, Release the left tab: step 3, image 2 of 2
      • Slide the left tab, labeled 1, to the unlocked position—it'll click into place and release the left side of the battery.
      Ask FixBot
    3. Lenovo ThinkPad X270 External Battery Replacement, Remove the battery: step 4, image 1 of 3 Lenovo ThinkPad X270 External Battery Replacement, Remove the battery: step 4, image 2 of 3 Lenovo ThinkPad X270 External Battery Replacement, Remove the battery: step 4, image 3 of 3
      • Hold the right tab, labeled 2, in the unlocked position and slide the battery out of its recess.
      • During reassembly, slide the battery into its recess until both tabs engage.
      • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
      Ask FixBot
Check your repair by running hardware tests with Lenovo Diagnostics.
For optimal performance, calibrate your newly installed battery after completing this guide.
5 other people completed this guide.
Spencer Day
206,618 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 35
Past 30 Days: 126
All Time: 1,965
