Lenovo ThinkPad X260 Internal Battery Replacement
    1. Lenovo ThinkPad X260 Internal Battery Replacement, External Battery: step 1, image 1 of 2 Lenovo ThinkPad X260 Internal Battery Replacement, External Battery: step 1, image 2 of 2
      • Make sure that the device is unplugged and turned off.
      • Flip the laptop from the front to the back.
      Ask FixBot
    2. Lenovo ThinkPad X260 Internal Battery Replacement: step 2, image 1 of 3 Lenovo ThinkPad X260 Internal Battery Replacement: step 2, image 2 of 3 Lenovo ThinkPad X260 Internal Battery Replacement: step 2, image 3 of 3
      • Start by pinching the switches on either side of the battery outwards.
      • At the same time push the external battery, located in the back, upwards.
      • Remove the external battery from the laptop.
      Ask FixBot
    1. Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: step 3, image 1 of 3 Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: step 3, image 2 of 3 Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: step 3, image 3 of 3
      • Loosen the eight 4.2 mm screws holding the back cover on using a Phillips #1 screwdriver.
      • These screws should be held in place by a small plastic washer which secures them to the cover and should not be loosened. This is illustrated in the third image.
      Ask FixBot
    2. Lenovo ThinkPad X260 Internal Battery Replacement: step 4, image 1 of 3 Lenovo ThinkPad X260 Internal Battery Replacement: step 4, image 2 of 3 Lenovo ThinkPad X260 Internal Battery Replacement: step 4, image 3 of 3
      • Gently pull the cover off and set aside.
      • An iFixit opening tool may make it easier to gently remove the cover.
      Ask FixBot
    1. Lenovo ThinkPad X260 Internal Battery Replacement, Internal Battery: step 5, image 1 of 2 Lenovo ThinkPad X260 Internal Battery Replacement, Internal Battery: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Detach the black battery connector using a pair of tweezers.
      Ask FixBot
    2. Lenovo ThinkPad X260 Internal Battery Replacement: step 6, image 1 of 1
      • Remove the four 3.3 mm screws locking down the battery using a Phillips #1 screwdriver.
      Ask FixBot
    3. Lenovo ThinkPad X260 Internal Battery Replacement: step 7, image 1 of 3 Lenovo ThinkPad X260 Internal Battery Replacement: step 7, image 2 of 3 Lenovo ThinkPad X260 Internal Battery Replacement: step 7, image 3 of 3
      • Carefully remove the internal battery unit from the laptop using an iFixit opening tool.
      • Pick up the battery and take it off the laptop frame.
      Ask FixBot
Ammarin Sinthana
125 Reputation
1 Guide authored
IUPUI, Team 1-3, Harley Summer 2023 Member of IUPUI, Team 1-3, Harley Summer 2023
IUPUI-HARLEY-SU23S1G3
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 13
Past 7 Days: 43
Past 30 Days: 163
All Time: 4,991
