Lenovo ThinkPad X260 Back Cover Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
91
All Time:
1,683
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 seconds - 2 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide is designed as a prerequisite guide to internal repairs of the Lenovo ThinkPad X260. Its simplicity will make the process of removing the bottom cover of the laptop easier.
The main reason that people will take off the back cover is to work on the internals of the laptop. Some examples of internal repairs are:
  • Replacing internal battery
  • Replacing cooling fan
  • Replacing motherboard
  • etc.
Make sure the computer is completely turned off before starting this guide.
Parts
Tools
    1. Lenovo ThinkPad X260 Back Cover Replacement, External Battery: step 1, image 1 of 2 Lenovo ThinkPad X260 Back Cover Replacement, External Battery: step 1, image 2 of 2
      • Make sure that the device is unplugged and turned off.
      • Flip the laptop from the front to the back.
      Ask FixBot
    2. Lenovo ThinkPad X260 Back Cover Replacement: step 2, image 1 of 3 Lenovo ThinkPad X260 Back Cover Replacement: step 2, image 2 of 3 Lenovo ThinkPad X260 Back Cover Replacement: step 2, image 3 of 3
      • Start by pinching the switches on either side of the battery outwards.
      • At the same time push the external battery, located in the back, upwards.
      • Remove the external battery from the laptop.
      Ask FixBot
    1. Lenovo ThinkPad X260 Back Cover Replacement, Back Cover: step 3, image 1 of 3 Lenovo ThinkPad X260 Back Cover Replacement, Back Cover: step 3, image 2 of 3 Lenovo ThinkPad X260 Back Cover Replacement, Back Cover: step 3, image 3 of 3
      • Loosen the eight 4.2 mm screws holding the back cover on using a Phillips #1 screwdriver.
      • These screws should be held in place by a small plastic washer which secures them to the cover and should not be loosened. This is illustrated in the third image.
      Ask FixBot
    2. Lenovo ThinkPad X260 Back Cover Replacement: step 4, image 1 of 3 Lenovo ThinkPad X260 Back Cover Replacement: step 4, image 2 of 3 Lenovo ThinkPad X260 Back Cover Replacement: step 4, image 3 of 3
      • Gently pull the cover off and set aside.
      • An iFixit opening tool may make it easier to gently remove the cover.
      Ask FixBot
Alexander Webb
210 Reputation
2 Guides authored
IUPUI, Team 1-3, Harley Summer 2023 Member of IUPUI, Team 1-3, Harley Summer 2023
IUPUI-HARLEY-SU23S1G3
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 91
All Time: 1,683
