Lenovo ThinkPad X250 RAM Replacement
    1. Lenovo ThinkPad X250 RAM Replacement, Removing the back cover: step 1, image 1 of 3 Lenovo ThinkPad X250 RAM Replacement, Removing the back cover: step 1, image 2 of 3 Lenovo ThinkPad X250 RAM Replacement, Removing the back cover: step 1, image 3 of 3
      • Unscrew the 8 screws holding the back panel in place.
      • Use a plastic prying tool to release all the clips holding the panel in place.
      Ask FixBot
    2. Lenovo ThinkPad X250 RAM Replacement, RAM Replacement: step 2, image 1 of 1
      • Push the metal latches outward on both sides of the memory slot to let the existing stick loose.
      • Pull the old module straight out of the socket.
      • Align the notch on your new RAM stick with the one inside the slot, and insert it at a 45-degree angle.
      • Press down on the top edge of the RAM module until the side latches click and lock it flat into place.
      • Ensure your new RAM stick follows the DDR3L 1600MHz SODIMM standard and does not exceed 16GB.
      Ask FixBot
Princemiguelcayetano
491 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 156
All Time: 2,321
