Lenovo ThinkPad X140e Keyboard Replacement
    1. Lenovo ThinkPad X140e Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Set the laptop facing you with the screen open.
      Ask FixBot
    2. Lenovo ThinkPad X140e Keyboard Replacement: step 2, image 1 of 2 Lenovo ThinkPad X140e Keyboard Replacement: step 2, image 2 of 2
      • Using a small plastic opening tool, pry off the keyboard starting at a point closest to you and working around the perimeter.
      Ask FixBot
    3. Lenovo ThinkPad X140e Keyboard Replacement: step 3, image 1 of 3 Lenovo ThinkPad X140e Keyboard Replacement: step 3, image 2 of 3 Lenovo ThinkPad X140e Keyboard Replacement: step 3, image 3 of 3
      • Flip up the ZIF connector that is holding the small ribbon cable in place.
      • Proceed to pull out the small ribbon cable
      Ask FixBot
    4. Lenovo ThinkPad X140e Keyboard Replacement: step 4, image 1 of 3 Lenovo ThinkPad X140e Keyboard Replacement: step 4, image 2 of 3 Lenovo ThinkPad X140e Keyboard Replacement: step 4, image 3 of 3
      • Flip up the ZIF connector that is holding the larger ribbon cable in place.
      • Proceed to pull out the large ribbon cable.
      Ask FixBot
2 other people completed this guide.
kevin hull
219 Reputation
2 Guides authored
Cal Poly, Team 20-5, Livingston Fall 2016 Member of Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 Members
60 Guides authored
4 Guide Comments
how can I buy a keyboard for my lenovo thinkpad x140e laptop?
Bryan - Reply Share
The keyboard for the X140e is the same as the one for the X130e and the X131e and the X121e.
It is FRU 04y0379
Buy the keyboard on eBay.
atexit8 - Reply Share
Just as a note, there are two screws that keep that keyboard held in place. You need to remove the back panel and take out those two screws, otherwise you’re going to have a tough time. Also, you really don’t need the pry tool, once those screws are out, the keyboard slides off. The rest of the process is spot on.
Jeffrey Chocklette - Reply Share
Don’t forget the screws, otherwise you will never get the keyboard off or worse damage it during removal
celticxxtwin - Reply Share
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 115
All Time: 2,491
