Lenovo ThinkPad X140e Back Panel Replacement
    1. Lenovo ThinkPad X140e Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Flip the laptop upside down so that the battery is facing away from you.
      • Battery removal is not necessary to complete this guide.
      Ask FixBot
    2. Lenovo ThinkPad X140e Back Panel Replacement: step 2, image 1 of 2 Lenovo ThinkPad X140e Back Panel Replacement: step 2, image 2 of 2
      • Locate the three 3 mm Phillips #0 screws on the back panel.
      • Remove each screw using a small Phillips #0 screwdriver.
      Ask FixBot
    3. Lenovo ThinkPad X140e Back Panel Replacement: step 3, image 1 of 1
      • Using a small plastic opening tool, pry off the back casing starting at a point closest to you and working around the perimeter of the case.
      Ask FixBot
Kenneth nguyen
232 Reputation
1 Guide authored
Cal Poly, Team 20-5, Livingston Fall 2016 Member of Cal Poly, Team 20-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 106
All Time: 891
