Lenovo ThinkPad X131e Disassembly
Featured Document
    1. Lenovo ThinkPad X131e Disassembly, External Battery Removal: step 1, image 1 of 2 Lenovo ThinkPad X131e Disassembly, External Battery Removal: step 1, image 2 of 2
      • Remove external battery by unlocking the safety latches near the external battery
      • Move the safety latches from the "Locked" to "Unlocked"
      Ask FixBot
    2. Lenovo ThinkPad X131e Disassembly, First Screws: step 2, image 1 of 1
      • Remove the two 7 mm Phillips 1 screws from the top left and right corners.
      • Two 7mm Phillips #1 screws
      • Unscrew the 3 captive screws (they will NOT come out, once they unscrew and "click," they are out of their socket)
      Ask FixBot
    3. Lenovo ThinkPad X131e Disassembly, Pry Bottom Cover: step 3, image 1 of 2 Lenovo ThinkPad X131e Disassembly, Pry Bottom Cover: step 3, image 2 of 2
      • Insert a plastic spudger and pry up the bottom cover from the laptop.
      Ask FixBot
    4. Lenovo ThinkPad X131e Disassembly, Access to Main Components/Hard Drive Removal: step 4, image 1 of 2 Lenovo ThinkPad X131e Disassembly, Access to Main Components/Hard Drive Removal: step 4, image 2 of 2
      • Here you can access RAM, HDD, WiFi and WiFi modules.
      • Remove the two 6 mm Phillips #1 screws holding down the HDD Cage
      • Then pull the HDD plastic pull tab at a slight angle to unseat the HDD from the computer.
      Ask FixBot
    5. Lenovo ThinkPad X131e Disassembly, Removal of WiFi Cards: step 5, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Removal of WiFi Cards: step 5, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Removal of WiFi Cards: step 5, image 3 of 3
      • Insert a plastic spudger underneath the antenna cable connections.
      • Be careful and make sure to pry up evenly as the connector is small and fragile. It will pop out with relatively small effort if prying at the correct angle.
      • Remove the two 4 mm Phillips #1 screws and then pull out the WiFi modules.
      Ask FixBot
    6. Lenovo ThinkPad X131e Disassembly, Remove Keyboard Screws: step 6, image 1 of 1
      • Remove the four 9 mm Phillips #1 screws that are holding down the keyboard.
      Ask FixBot
    7. Lenovo ThinkPad X131e Disassembly, Removal of the Keyboard: step 7, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Removal of the Keyboard: step 7, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Removal of the Keyboard: step 7, image 3 of 3
      • Press both hands down firmly on the keyboard and slide forward to unseat the keyboard.
      • Next lift and slightly pull out the keyboard.
      • Be careful when lifting the keyboard as there are two ribbon cables attached to the main laptop which can tear easily.
      Ask FixBot
    8. Lenovo ThinkPad X131e Disassembly, Disconnecting Keyboard Ribbon Cables: step 8, image 1 of 2 Lenovo ThinkPad X131e Disassembly, Disconnecting Keyboard Ribbon Cables: step 8, image 2 of 2
      • Unlatch the ribbon cables' retaining flap with a plastic spudger.
      • Note: When reattaching the ribbon cables, they don't slide "in" to their connector, they lay on the pins, and what holds them down is their retaining flap.
      • Make sure the pins are aligned with the ribbon cable when securing the retaining flap.
      Ask FixBot
    9. Lenovo ThinkPad X131e Disassembly, Removing Top Cover: step 9, image 1 of 1
      • Unscrew the three 5 mm Phillips #1 screws that are holding down the top cover.
      Ask FixBot
    10. Lenovo ThinkPad X131e Disassembly, Disconnecting Trackpad Ribbon Cable: step 10, image 1 of 2 Lenovo ThinkPad X131e Disassembly, Disconnecting Trackpad Ribbon Cable: step 10, image 2 of 2
      • Use a plastic spudger to lift the lap on the trackpad's ribbon cable.
      • Then carefully pull out the ribbon cable.
      Ask FixBot
    11. Lenovo ThinkPad X131e Disassembly, Disconnecting Microphone Cable: step 11, image 1 of 2 Lenovo ThinkPad X131e Disassembly, Disconnecting Microphone Cable: step 11, image 2 of 2
      • With your fingers, grip the other exposed cable and carefully pull out horizontally to disconnect the connection.
      Ask FixBot
    12. Lenovo ThinkPad X131e Disassembly, Prying Off Top Cover: step 12, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Prying Off Top Cover: step 12, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Prying Off Top Cover: step 12, image 3 of 3
      • Insert a plastic spudger in between the top cover and frame of the laptop. Start prying, making your way around the whole laptop.
      • Remember to make sure the two 7 mm screws from Step #2 have been removed or else the top cover will not come off.
      Ask FixBot
    13. Lenovo ThinkPad X131e Disassembly, Disconnect Speaker Wire: step 13, image 1 of 2 Lenovo ThinkPad X131e Disassembly, Disconnect Speaker Wire: step 13, image 2 of 2
      Tool used on this step:
      Buy
      • Disconnect the speaker wire from the motherboard with your fingers or tweezers.
      Ask FixBot
    14. Lenovo ThinkPad X131e Disassembly: step 14, image 1 of 2 Lenovo ThinkPad X131e Disassembly: step 14, image 2 of 2
      • Remove the four 6 mm Phillips #1 screws holding down the speakers near the bottom of the case.
      • Pull out the two speakers and their wiring carefully.
      Ask FixBot
    15. Lenovo ThinkPad X131e Disassembly, Removing Screws from the Motherboard: step 15, image 1 of 1
      • Remove the five 4 mm Phillips #1 screws.
      • These can be identified by a small white arrow pointing towards their socket.
      • Remove the two 6 mm Phillips #1 screws near the middle of the board.
      Ask FixBot
    16. Lenovo ThinkPad X131e Disassembly, Disconnecting Ribbon Cables: step 16, image 1 of 2 Lenovo ThinkPad X131e Disassembly, Disconnecting Ribbon Cables: step 16, image 2 of 2
      • Disconnect the safety latch near the bottom right with a plastic spudger and carefully remove the ribbon cable.
      Ask FixBot
    17. Lenovo ThinkPad X131e Disassembly, Disconnecting More Ribbon Cables: step 17, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Disconnecting More Ribbon Cables: step 17, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Disconnecting More Ribbon Cables: step 17, image 3 of 3
      • Insert a plastic spudger to remove the safety latch of the top middle ribbon cable, then disconnect the ribbon cable.
      • when the ribbon cable meets the fold, carefully peel the cable off as there is some adhesive holding it down in place.
      Ask FixBot
    18. Lenovo ThinkPad X131e Disassembly, Disconnecting Another Cable: step 18, image 1 of 2 Lenovo ThinkPad X131e Disassembly, Disconnecting Another Cable: step 18, image 2 of 2
      • Disconnect the last visible cable by pushing it horizontally out with a plastic spudger.
      Ask FixBot
    19. Lenovo ThinkPad X131e Disassembly, Remove the Smaller Boards: step 19, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Remove the Smaller Boards: step 19, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Remove the Smaller Boards: step 19, image 3 of 3
      • Remove the small boards on the top left and right of the laptop with either your hands or tweezers.
      Ask FixBot
    20. Lenovo ThinkPad X131e Disassembly, Disconnecting Display Ribbon Cable: step 20, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Disconnecting Display Ribbon Cable: step 20, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Disconnecting Display Ribbon Cable: step 20, image 3 of 3
      • Peel off from the right of the sticker, there will be a black plastic pull tab that is there.
      • With your fingers, grip and pull the tab up vertically, with some force, the connector will disconnect.
      Ask FixBot
    21. Lenovo ThinkPad X131e Disassembly, Removing the Motherboard: step 21, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Removing the Motherboard: step 21, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Removing the Motherboard: step 21, image 3 of 3
      • Insert plastic spudger from the left and slightly raise the motherboard.
      • There are plastic pegs on the left side of the motherboard, insert another pry tool or a finger underneath from the right side of the motherboard and lift "up" a bit to free the motherboard from the pegs.
      • After that, you can pull the motherboard away by pulling to the left.
      Ask FixBot
    22. Lenovo ThinkPad X131e Disassembly, Disconnecting Power Delivery Cable: step 22, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Disconnecting Power Delivery Cable: step 22, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Disconnecting Power Delivery Cable: step 22, image 3 of 3
      • Flip the motherboard to its other side.
      • Then pull out the charging cable by holding it with your fingers and "wiggling" it out.
      • The motherboard is now free.
      Ask FixBot
    23. Lenovo ThinkPad X131e Disassembly, Remove the WiFi and Cellular Antenna Cables: step 23, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Remove the WiFi and Cellular Antenna Cables: step 23, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Remove the WiFi and Cellular Antenna Cables: step 23, image 3 of 3
      • Grab the black and blue antenna cables carefully pull them out of their path until they're no longer held down.
      Ask FixBot
    24. Lenovo ThinkPad X131e Disassembly, Remove the WiFi and Cellular Antenna Cables Continued: step 24, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Remove the WiFi and Cellular Antenna Cables Continued: step 24, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Remove the WiFi and Cellular Antenna Cables Continued: step 24, image 3 of 3
      • Do the same thing with the gray and red antenna cables.
      Ask FixBot
    25. Lenovo ThinkPad X131e Disassembly, Free the Last Display Cable: step 25, image 1 of 2 Lenovo ThinkPad X131e Disassembly, Free the Last Display Cable: step 25, image 2 of 2
      • Grab and remove the last cable from its place.
      Ask FixBot
    26. Lenovo ThinkPad X131e Disassembly, Remove the Hinge's Screws: step 26, image 1 of 2 Lenovo ThinkPad X131e Disassembly, Remove the Hinge's Screws: step 26, image 2 of 2
      • Remove the four 6 mm Phillips #1 screws from the hinges.
      • The display will now be free.
      • Note: If you noticed any screws attached to my hinges, those are there because my computer's frame is broken, and I didn't want to lose the threading for the screws. If your frame isn't broken, then there won't be any screws left on the hinges.
      Ask FixBot
    27. Lenovo ThinkPad X131e Disassembly, Removing Charging Port: step 27, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Removing Charging Port: step 27, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Removing Charging Port: step 27, image 3 of 3
      • The charging port is held down with pressure
      • Stick a plastic spudger on the bottom port of the charging port and pry up to remove the port.
      Ask FixBot
    28. Lenovo ThinkPad X131e Disassembly, Disassembly of Display: step 28, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Disassembly of Display: step 28, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Disassembly of Display: step 28, image 3 of 3
      • Now that the display is free, insert a thin metal prying tool like tweezers or a needle to pry off the plastic screw covers in the four corners.
      Ask FixBot
    29. Lenovo ThinkPad X131e Disassembly, Removal of Bezel: step 29, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Removal of Bezel: step 29, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Removal of Bezel: step 29, image 3 of 3
      • Now insert a plastic spudger between the top of the assembly and the bezel and start prying.
      • Make your way around the bezel. You can also pry from the other side of the bezel by the screen with your finger to make it easier.
      Ask FixBot
    30. Lenovo ThinkPad X131e Disassembly, Removal of Bezel Continued: step 30, image 1 of 2 Lenovo ThinkPad X131e Disassembly, Removal of Bezel Continued: step 30, image 2 of 2
      • Keep prying until the bezel is free.
      Ask FixBot
    31. Lenovo ThinkPad X131e Disassembly, Unscrewing LCD Panel: step 31, image 1 of 1
      • Remove the four 4 mm silver screws holding down the LCD panel.
      Ask FixBot
    32. Lenovo ThinkPad X131e Disassembly, Before Removing LCD Panel: step 32, image 1 of 2 Lenovo ThinkPad X131e Disassembly, Before Removing LCD Panel: step 32, image 2 of 2
      • Lift and remove the silver shielded wire connected to the LCD panel out of the way.
      Ask FixBot
    33. Lenovo ThinkPad X131e Disassembly, Removing LCD Panel: step 33, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Removing LCD Panel: step 33, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Removing LCD Panel: step 33, image 3 of 3
      • Use a plastic prying tool near the edge of the panel where the silver screws once were to lift up the LCD panel.
      • The LCD panel is now free.
      Ask FixBot
    34. Lenovo ThinkPad X131e Disassembly, Removing Hinge Assembly: step 34, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Removing Hinge Assembly: step 34, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Removing Hinge Assembly: step 34, image 3 of 3
      • Remove the two 6 mm screws holding down the two hinge assemblies.
      • The hinges are no longer secured to the frame and can be lifted away.
      Ask FixBot
    35. Lenovo ThinkPad X131e Disassembly, Webcam and Microphone Removal: step 35, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Webcam and Microphone Removal: step 35, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Webcam and Microphone Removal: step 35, image 3 of 3
      • The webcam and microphone are both attached to a silver shielded cable.
      • The webcam assembly can be lifted away.
      • There is black tape over the microphone that can be peeled off by tweezers, and then the microphones can be lifted away too.
      Ask FixBot
    36. Lenovo ThinkPad X131e Disassembly, Webcam and Microphone Removal Continued: step 36, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Webcam and Microphone Removal Continued: step 36, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Webcam and Microphone Removal Continued: step 36, image 3 of 3
      • Peel away the black cloth tape covering the microphone Printed Circuit Board (PCB)
      • The microphone's PCB is glued down. Insert a plastic spudger from the left and make your way to the right to slowly release the microphone's PCB.
      • With that, the microphone along with the webcam are now free.
      Ask FixBot
    37. Lenovo ThinkPad X131e Disassembly, Shielded Cable Removal: step 37, image 1 of 2 Lenovo ThinkPad X131e Disassembly, Shielded Cable Removal: step 37, image 2 of 2
      • Farther down the same shielded cable, there is more black cloth tape.
      • Peel it away with some pliers.
      Ask FixBot
    38. Lenovo ThinkPad X131e Disassembly, Shielded Cable Removal: step 38, image 1 of 2 Lenovo ThinkPad X131e Disassembly, Shielded Cable Removal: step 38, image 2 of 2
      • Because the small PCB is glued down with adhesive, insert a plastic spudger from the left, underneath the shielded cable, to pry it away.
      Ask FixBot
    39. Lenovo ThinkPad X131e Disassembly, Removal of Shielded Cable Continued: step 39, image 1 of 2 Lenovo ThinkPad X131e Disassembly, Removal of Shielded Cable Continued: step 39, image 2 of 2
      • Carefully peel away the rest of the shielded cable.
      • Make sure to remove the cable from its cable routing carefully when you get to the bottom.
      • The cable is now free.
      Ask FixBot
    40. Lenovo ThinkPad X131e Disassembly, Removing WiFi Antenna Cables: step 40, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Removing WiFi Antenna Cables: step 40, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Removing WiFi Antenna Cables: step 40, image 3 of 3
      • Lift the cable shielding covering the cable routing for the WiFi and cellular antennas.
      • Start removing the cable's from their routing slots.
      Ask FixBot
    41. Lenovo ThinkPad X131e Disassembly, Removing WiFi Antenna Cables Continued: step 41, image 1 of 1
      • Keep removing until you get to the top two black PCB's that the cables are attached to the frame.
      Ask FixBot
    42. Lenovo ThinkPad X131e Disassembly, Removing WiFi Antenna Cables Continued: step 42, image 1 of 3 Lenovo ThinkPad X131e Disassembly, Removing WiFi Antenna Cables Continued: step 42, image 2 of 3 Lenovo ThinkPad X131e Disassembly, Removing WiFi Antenna Cables Continued: step 42, image 3 of 3
      • Insert a plastic spudger between the the PCB and the frame, and carefully pry up.
      • The PCB should lift with relatively little effort.
      • Now do the same with the other PCB.
      Ask FixBot
    43. Lenovo ThinkPad X131e Disassembly, Removing WiFi Antenna Cables Continued: step 43, image 1 of 2 Lenovo ThinkPad X131e Disassembly, Removing WiFi Antenna Cables Continued: step 43, image 2 of 2
      • Peel away the PCB's and their attached copper tape carefully.
      • Please see the next step if the silver shielding is peeling away with the copper tape.
      Ask FixBot
    44. Lenovo ThinkPad X131e Disassembly, If the Silver Shielding is Peeling with the Copper Tape: step 44, image 1 of 2 Lenovo ThinkPad X131e Disassembly, If the Silver Shielding is Peeling with the Copper Tape: step 44, image 2 of 2
      • If the Silver Shielding starts to peel away with the copper tape, then insert a plastic pry tool from the bottom (other side) and start peeling from there.
      • Now the silver shielding won't get damaged.
      Ask FixBot
    45. Lenovo ThinkPad X131e Disassembly, Removing WiFi Antenna Cables Continued: step 45, image 1 of 1
      • Repeat steps 40-44 on the other side with the other antenna cable.
      Ask FixBot
    46. Lenovo ThinkPad X131e Disassembly, Disassembly Complete!: step 46, image 1 of 1
      • The laptop is now fully disassembled. Thanks for reading my guide!
      Ask FixBot
I’ve attached the Hardware Maintenance Manual from Lenovo for this machine in case you need a more specific guide to a certain part.
If I missed something, let me know and I’ll update the guide!
2 other people completed this guide.
Saul Torres
643 Reputation
1 Guide authored
1 Guide Comment
Fantastic resource, thank you!
John Saponara - Reply Share
Past 24 Hours: 4
Past 7 Days: 41
Past 30 Days: 155
All Time: 4,724
