Lenovo ThinkPad X100e Screen Replacement
    1. Lenovo ThinkPad X100e Screen Replacement, Screen: step 1, image 1 of 2 Lenovo ThinkPad X100e Screen Replacement, Screen: step 1, image 2 of 2
      Tool used on this step:
      Spudger
      $2.99
      Buy
      • Use a Spudger tool to remove the screw covers on each side of the screen.
      • Be sure not to lose screw covers.
      Ask FixBot
    2. Lenovo ThinkPad X100e Screen Replacement: step 2, image 1 of 1
      • Using a magnetic screwdriver fit with a PH0 Bit, unscrew the two screws and carefully set the aside.
      Ask FixBot
    3. Lenovo ThinkPad X100e Screen Replacement: step 3, image 1 of 1
      • Pry open the bezel carefully with the spudger tool.
      • You will want to do this until the frame is completely off.
      Ask FixBot
    4. Lenovo ThinkPad X100e Screen Replacement: step 4, image 1 of 1
      • Remove all exposed screws and carefully set them aside. There should be 6 visible screws.
      • Be sure to set the screws aside on the magnetic mat.
      Ask FixBot
    5. Lenovo ThinkPad X100e Screen Replacement: step 5, image 1 of 1
      • Lift the screen up carefully, and remove the screws on both sides of the panel. There should be 4 screws.
      • The other two screws are located in the exact place on the other side.
      • Don't forget to place the screws on the magnetic mat, separate from other screws.
      Ask FixBot
    6. Lenovo ThinkPad X100e Screen Replacement: step 6, image 1 of 2 Lenovo ThinkPad X100e Screen Replacement: step 6, image 2 of 2
      • Remove the connector located at the very top of the screen beside the webcam.
      • To remove the connector, simply pull the connector out.
      Ask FixBot
    7. Lenovo ThinkPad X100e Screen Replacement: step 7, image 1 of 1
      • Fold the panel over until a strip of black tape is visible.
      • Peel the tape down until you get to the base.
      Ask FixBot
    8. Lenovo ThinkPad X100e Screen Replacement: step 8, image 1 of 2 Lenovo ThinkPad X100e Screen Replacement: step 8, image 2 of 2
      • Peel the piece of transparent tape back.
      • At this point there should be some exposed wires underneath the tape.
      Ask FixBot
    9. Lenovo ThinkPad X100e Screen Replacement: step 9, image 1 of 1
      • Remove the connector carefully with the spudger tool.
      Ask FixBot
    10. Lenovo ThinkPad X100e Screen Replacement: step 10, image 1 of 1
      • Remove the black tape fully.
      • Now your device is ready for a new panel.
      Ask FixBot
Orly Guerra
457 Reputation
2 Guides authored
1 Guide Comment
What can be used as a replacement screen, as it's listed not for sale?
Keith Bowe - Reply Share
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 74
All Time: 1,450
