Lenovo ThinkPad X100e RAM Replacement
    1. Lenovo ThinkPad X100e RAM Replacement, RAM: step 1, image 1 of 1
      • Power off the device completely.
      • Use the Phillips #0 screwdriver to remove the seven screws that are holding the bottom cover in place.
      • Remove the back cover from the frame.
      Ask FixBot
    2. Lenovo ThinkPad X100e RAM Replacement: step 2, image 1 of 1
      • The RAM will be located at the bottom right corner of the laptop.
      Ask FixBot
    3. Lenovo ThinkPad X100e RAM Replacement: step 3, image 1 of 2 Lenovo ThinkPad X100e RAM Replacement: step 3, image 2 of 2
      • Pull the two mounting clips on either side of the RAM stick away from the RAM stick.
      • The RAM should lift up 30 degrees. Slide it out gently as to not damage the pins.
      Ask FixBot
Replace the RAM by sliding the new stick back into the empty slot until it clicks into place.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 76
All Time: 1,927
