Lenovo ThinkPad X1 Yoga Keyboard Replacement
    1. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Back Cover: step 1, image 1 of 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Back Cover: step 1, image 2 of 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Back Cover: step 1, image 3 of 3
      • Be sure to power off and unplug your device before you begin your repair.
      • Flip the computer over so the bottom is facing up.
      • Remove nine 4mm Phillips #1 screws from the bottom of the computer.
      • Use an iFixit opening tool to pry the back cover off of the laptop.
      Ask FixBot
    1. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Speakers: step 2, image 1 of 1
      • Remove the five 4.5mm Phillips #1 screws that secure the battery.
      Ask FixBot
    2. Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Using a pair of tweezers, push the sides of the white speaker wire toward the battery (where it says Lenovo) to unplug it.
      Ask FixBot
    3. Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 4, image 1 of 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 4, image 2 of 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 4, image 3 of 3
      • Remove the speakers from either side of the battery. The connecting wire will unthread from the sides of the battery.
      Ask FixBot
    1. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Battery: step 5, image 1 of 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Battery: step 5, image 2 of 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Battery: step 5, image 3 of 3
      • Lift the plastic black strip cover that's laying over the battery connector.
      • Use the iFixit opening tool to flip up and disconnect the black battery connector from its motherboard socket.
      • Gently pull the connector away from the battery to pull it out of the slot.
      Ask FixBot
    2. Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 6, image 1 of 1
      • Lift and remove the battery away from the computer.
      Ask FixBot
    1. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Cooling Fan: step 7, image 1 of 1
      • Remove four 4.5mm Phillips #1 screws from the corners of the heat sink.
      Ask FixBot
    2. Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 8, image 1 of 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 8, image 2 of 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 8, image 3 of 3
      • Gently peel back the black plastic covering around the fan.
      • You may hear or feel the adhesive pulling away here.
      • Using an iFixit opening tool, flip up the small black cover of the fan plug.
      Ask FixBot
    3. Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 9, image 1 of 2 Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 9, image 2 of 2
      Buy
      • Using tweezers, pull the plastic strip out.
      Ask FixBot
    4. Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 10, image 1 of 2 Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 10, image 2 of 2
      • Remove the fan from the computer.
      Ask FixBot
    1. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Wireless chip: step 11, image 1 of 1
      • Gently peel back the black plastic covering.
      • Remove the single Phillips #1 screw securing the wireless chip in place.
      Ask FixBot
    2. Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 12, image 1 of 2 Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 12, image 2 of 2
      • Use an iFixit opening tool to gently pop the gold caps off their connections.
      • Move these wires out of the way.
      Ask FixBot
    3. Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 13, image 1 of 1
      • Slide the chip out.
      Ask FixBot
    1. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Hard Drive: step 14, image 1 of 2 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Hard Drive: step 14, image 2 of 2
      • Remove the single 2mm Phillips #1 screw from the hard drive's silver casing.
      Ask FixBot
    2. Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 15, image 1 of 1
      • Unplug the hard drive from the computer by pulling away from the computer.
      Ask FixBot
    1. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Motherboard: step 16, image 1 of 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Motherboard: step 16, image 2 of 3 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Motherboard: step 16, image 3 of 3
      • Using the iFixit opening tool, flip up the eight small covers from the cable connectors.
      • Gently pull the cables out of the slots.
      Ask FixBot
    2. Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 17, image 1 of 2 Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 17, image 2 of 2
      • Using the Phillips #1 screwdriver, remove sixteen 4.5mm screws.
      Ask FixBot
    3. Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 18, image 1 of 1
      • Lift and remove the motherboard away from the computer.
      Ask FixBot
    1. Lenovo ThinkPad X1 Yoga Keyboard Replacement, Keyboard: step 19, image 1 of 2 Lenovo ThinkPad X1 Yoga Keyboard Replacement, Keyboard: step 19, image 2 of 2
      • Using the Phillips #1 screwdriver, remove 23 (twenty three) 4.5mm screws.
      Ask FixBot
    2. Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 20, image 1 of 1
      • Using the iFixit opening tool, lift the metal frame away from the keyboard.
      Ask FixBot
    3. Lenovo ThinkPad X1 Yoga Keyboard Replacement: step 21, image 1 of 1
      • Lift and remove the keyboard away from the computer.
      Ask FixBot
9 other people completed this guide.
2 Guide Comments
Samw steps on gen 4, screws just in different places, thie guide worked great! Thanks :)
Ryan B - Reply Share
there's no need to remove the heat sink, SSD and wireless cards - you can just remove the motherboard in 1 piece with these still attached.
Slim - Reply Share
Past 24 Hours: 5
Past 7 Days: 48
Past 30 Days: 195
All Time: 19,405
