Lenovo ThinkPad X1 Extreme RAM Replacement
    1. Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: step 1, image 1 of 3 Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: step 1, image 2 of 3 Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: step 1, image 3 of 3
      • Power off and unplug your device before you begin.
      • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
      • Unscrew the seven captive screws with a Phillips #00 screwdriver.
      • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
      • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
      • Remove the back cover from the device.
      Ask FixBot
    1. Lenovo ThinkPad X1 Extreme RAM Replacement, RAM: step 2, image 1 of 1
      • Use an opening tool to unlatch the silver gate on the side of the RAM by pushing it away from the component.
      • Repeat the same process to the other side of the RAM.
      Ask FixBot
    2. Lenovo ThinkPad X1 Extreme RAM Replacement: step 3, image 1 of 1
      • Gently grab the RAM and slide it up and away from the connector at the bottom of the component.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 107
All Time: 2,058
