Lenovo ThinkPad X1 Extreme Hinges Replacement
    1. Lenovo ThinkPad X1 Extreme Hinges Replacement, Back Cover: step 1, image 1 of 3 Lenovo ThinkPad X1 Extreme Hinges Replacement, Back Cover: step 1, image 2 of 3 Lenovo ThinkPad X1 Extreme Hinges Replacement, Back Cover: step 1, image 3 of 3
      • Power off and unplug your device before you begin.
      • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
      • Unscrew the seven captive screws with a Phillips #00 screwdriver.
      • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
      • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
      • Remove the back cover from the device.
      Ask FixBot
    1. Lenovo ThinkPad X1 Extreme Hinges Replacement, Speakers: step 2, image 1 of 1
      • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
      Ask FixBot
    2. Lenovo ThinkPad X1 Extreme Hinges Replacement: step 3, image 1 of 1
      • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
      • Set the speaker modules out of the way.
      Ask FixBot
    1. Lenovo ThinkPad X1 Extreme Hinges Replacement, Battery: step 4, image 1 of 3 Lenovo ThinkPad X1 Extreme Hinges Replacement, Battery: step 4, image 2 of 3 Lenovo ThinkPad X1 Extreme Hinges Replacement, Battery: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to peel the plastic cover off the connector.
      • Use a plastic spudger or your fingernail to pry up the battery connector straight up from the motherboard.
      Ask FixBot
    2. Lenovo ThinkPad X1 Extreme Hinges Replacement: step 5, image 1 of 1
      • Lift the battery out of the frame and remove it from the device.
      Ask FixBot
    1. Lenovo ThinkPad X1 Extreme Hinges Replacement, Hinges: step 6, image 1 of 3 Lenovo ThinkPad X1 Extreme Hinges Replacement, Hinges: step 6, image 2 of 3 Lenovo ThinkPad X1 Extreme Hinges Replacement, Hinges: step 6, image 3 of 3
      • Remove back panel and locate the connecting wires.
      • Disconnect the display connections on the motherboard.
      • Use a Phillips #00 screwdriver to remove the six screws (three on each hinge) securing the hinges to the main chassis.
      Ask FixBot
    2. Lenovo ThinkPad X1 Extreme Hinges Replacement: step 7, image 1 of 3 Lenovo ThinkPad X1 Extreme Hinges Replacement: step 7, image 2 of 3 Lenovo ThinkPad X1 Extreme Hinges Replacement: step 7, image 3 of 3
      • Flip the display face up, then wedge a Jimmy between the display and the bezel, sliding and prying around the perimeter until the bezel releases.
      • Unscrew the first two exposed 1.2 mm screws with a Phillips #1 screwdriver, then peel back the adhesive to find and remove the third screw.
      • Lift the hinges up and off the display.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 45
All Time: 1,830
