Lenovo ThinkPad X1 Extreme Camera Replacement
    1. Lenovo ThinkPad X1 Extreme Camera Replacement, Back Cover: step 1, image 1 of 3 Lenovo ThinkPad X1 Extreme Camera Replacement, Back Cover: step 1, image 2 of 3 Lenovo ThinkPad X1 Extreme Camera Replacement, Back Cover: step 1, image 3 of 3
      • Power off and unplug your device before you begin.
      • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
      • Unscrew the seven captive screws with a Phillips #00 screwdriver.
      • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
      • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
      • Remove the back cover from the device.
      Ask FixBot
    1. Lenovo ThinkPad X1 Extreme Camera Replacement, Speakers: step 2, image 1 of 1
      • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
      Ask FixBot
    2. Lenovo ThinkPad X1 Extreme Camera Replacement: step 3, image 1 of 1
      • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
      • Set the speaker modules out of the way.
      Ask FixBot
    1. Lenovo ThinkPad X1 Extreme Camera Replacement, Battery: step 4, image 1 of 3 Lenovo ThinkPad X1 Extreme Camera Replacement, Battery: step 4, image 2 of 3 Lenovo ThinkPad X1 Extreme Camera Replacement, Battery: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to peel the plastic cover off the connector.
      • Use a plastic spudger or your fingernail to pry up the battery connector straight up from the motherboard.
      Ask FixBot
    2. Lenovo ThinkPad X1 Extreme Camera Replacement: step 5, image 1 of 1
      • Lift the battery out of the frame and remove it from the device.
      Ask FixBot
    1. Lenovo ThinkPad X1 Extreme Camera Replacement, Display: step 6, image 1 of 2 Lenovo ThinkPad X1 Extreme Camera Replacement, Display: step 6, image 2 of 2
      • Gently take off the cover of the hinge of the computer with a combination of the opening tool and your hands.
      Ask FixBot
    2. Lenovo ThinkPad X1 Extreme Camera Replacement: step 7, image 1 of 1
      • Lift up the covering of the display using the opening tool.
      Ask FixBot
    3. Lenovo ThinkPad X1 Extreme Camera Replacement: step 8, image 1 of 1
      • Use a spudger to release the retaining flap on the cable connector.
      Ask FixBot
    4. Lenovo ThinkPad X1 Extreme Camera Replacement: step 9, image 1 of 2 Lenovo ThinkPad X1 Extreme Camera Replacement: step 9, image 2 of 2
      • Pull the wire that was connected to the retaining flap through the hinge.
      • Remove the display from the laptop.
      Ask FixBot
    1. Lenovo ThinkPad X1 Extreme Camera Replacement, Camera: step 10, image 1 of 2 Lenovo ThinkPad X1 Extreme Camera Replacement, Camera: step 10, image 2 of 2
      • Detach the wire that's connected to the camera.
      • Remove the camera.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 93
All Time: 1,494
