Lenovo ThinkPad W540 Display Replacement
    1. Lenovo ThinkPad W540 Display Replacement, Display: step 1, image 1 of 2 Lenovo ThinkPad W540 Display Replacement, Display: step 1, image 2 of 2
      • Open your laptop so that the screen is at around a 180 degree angle.
      • Using a plastic opening tool, pry open the outer frame of the display.
      • Generally, it is best practice to start from the corner first, and then guide the opening tool around the the frame.
      Ask FixBot
    2. Lenovo ThinkPad W540 Display Replacement: step 2, image 1 of 2 Lenovo ThinkPad W540 Display Replacement: step 2, image 2 of 2
      • Use a Phillips #00 screwdriver to unscrew the four 3 mm screws holding the display, one for each corner.
      • Once unscrewed, flip the display over the other side of the laptop (keyboard end).
      Ask FixBot
    3. Lenovo ThinkPad W540 Display Replacement: step 3, image 1 of 2 Lenovo ThinkPad W540 Display Replacement: step 3, image 2 of 2
      • Use a plastic spudger, safety lift the adhesive tape from the connector.
      • Do not disregard the tape from the connector entirely as you will be reusing it later.
      • This adhesive tape will be strong, remove the tape carefully to prevent damage to the display connector.
      Ask FixBot
    4. Lenovo ThinkPad W540 Display Replacement: step 4, image 1 of 1
      • Safely disconnect the display from the connector.
      • Although you can use your hands to disconnect the connector, it is recommended that you use a spudger instead.
      Ask FixBot
2 other people completed this guide.
Kevin Dang
360 Reputation
2 Guides authored
UMass Dartmouth, Team 3-2, Konn Fall 2023 Member of UMass Dartmouth, Team 3-2, Konn Fall 2023
UMASSD-KONN-F23S3G2
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 28
Past 30 Days: 106
All Time: 1,067
