Lenovo ThinkPad Ultra Dock broken lock replacement
    1. Lenovo ThinkPad Ultra Dock broken lock replacement, Broken key lock: step 1, image 1 of 1
      • Remove all marked screws and keep them save
      • The colors of the screws might be exchanged
      • For best results please remind yourself which screws you removed from where
      Ask FixBot
    2. Lenovo ThinkPad Ultra Dock broken lock replacement: step 2, image 1 of 3 Lenovo ThinkPad Ultra Dock broken lock replacement: step 2, image 2 of 3 Lenovo ThinkPad Ultra Dock broken lock replacement: step 2, image 3 of 3
      • Remove also those screws
      Ask FixBot
    3. Lenovo ThinkPad Ultra Dock broken lock replacement: step 3, image 1 of 1
      • lift the cover carefully till the clips snap out
      • remove the cover completely by trying to pull it downwards
      • The right clip on top might be a little hard to pop out: So be careful! It might help if you remove all the other clips first
      Ask FixBot
    4. Lenovo ThinkPad Ultra Dock broken lock replacement: step 4, image 1 of 1
      • next lose this screw as well
      Ask FixBot
    5. Lenovo ThinkPad Ultra Dock broken lock replacement: step 5, image 1 of 1
      • You can use a plektrum to open up your device. You might will have to repeat the step multiple times. Make sure that you take care of every slit
      • If you don't have a plektrum just use your fingernails or something similar. But be careful it might will hurt you
      Ask FixBot
    6. Lenovo ThinkPad Ultra Dock broken lock replacement: step 6, image 1 of 2 Lenovo ThinkPad Ultra Dock broken lock replacement: step 6, image 2 of 2
      • I suggest you to glue the spring on the second picture on the bottom. It will be easier for to reassemble the device later
      Ask FixBot
    7. Lenovo ThinkPad Ultra Dock broken lock replacement: step 7, image 1 of 3 Lenovo ThinkPad Ultra Dock broken lock replacement: step 7, image 2 of 3 Lenovo ThinkPad Ultra Dock broken lock replacement: step 7, image 3 of 3
      • Remove all the marked screws in order to remove the lock mecanism
      Ask FixBot
    8. Lenovo ThinkPad Ultra Dock broken lock replacement: step 8, image 1 of 2 Lenovo ThinkPad Ultra Dock broken lock replacement: step 8, image 2 of 2
      • Pull out the placeholder
      Ask FixBot
    9. Lenovo ThinkPad Ultra Dock broken lock replacement: step 9, image 1 of 1
      • Remove also this screw and the plastic part which is held by it
      Ask FixBot
    10. Lenovo ThinkPad Ultra Dock broken lock replacement: step 10, image 1 of 2 Lenovo ThinkPad Ultra Dock broken lock replacement: step 10, image 2 of 2
      • remove the lock
      • Try to bend all the metall structures back into their right shape
      • But pay attention that the metall doesn't break!
      Ask FixBot
    11. Lenovo ThinkPad Ultra Dock broken lock replacement: step 11, image 1 of 2 Lenovo ThinkPad Ultra Dock broken lock replacement: step 11, image 2 of 2
      • This spring snaps out very easy so pay attention that it is still inplace before you assemble every thing again
      • Watch out for the tape! Make sure that it is covering the cables and make also sure that the cables are on the right place
      Ask FixBot
Reverse those steps to reassemble the device
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Jonas Braun
384 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 51
All Time: 5,339
