Lenovo ThinkPad T580 Trackpad Replacement
  1. Lenovo ThinkPad T580 Trackpad Replacement, External Battery: step 1, image 1 of 3 Lenovo ThinkPad T580 Trackpad Replacement, External Battery: step 1, image 2 of 3 Lenovo ThinkPad T580 Trackpad Replacement, External Battery: step 1, image 3 of 3
    • Slide the switch on the left side of the battery to the left.
    Ask FixBot
  2. Lenovo ThinkPad T580 Trackpad Replacement: step 2, image 1 of 3 Lenovo ThinkPad T580 Trackpad Replacement: step 2, image 2 of 3 Lenovo ThinkPad T580 Trackpad Replacement: step 2, image 3 of 3
    • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
    Ask FixBot
  3. Lenovo ThinkPad T580 Trackpad Replacement: step 3, image 1 of 3 Lenovo ThinkPad T580 Trackpad Replacement: step 3, image 2 of 3 Lenovo ThinkPad T580 Trackpad Replacement: step 3, image 3 of 3
    • Pull the battery directly out of the socket
    Ask FixBot
  4. Lenovo ThinkPad T580 Trackpad Replacement, Bottom Case: step 4, image 1 of 2 Lenovo ThinkPad T580 Trackpad Replacement, Bottom Case: step 4, image 2 of 2
    • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
    • The "captive" screws will not come out of the case.
    Ask FixBot
  5. Lenovo ThinkPad T580 Trackpad Replacement: step 5, image 1 of 3 Lenovo ThinkPad T580 Trackpad Replacement: step 5, image 2 of 3 Lenovo ThinkPad T580 Trackpad Replacement: step 5, image 3 of 3
    • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
    Ask FixBot
  6. Lenovo ThinkPad T580 Trackpad Replacement: step 6, image 1 of 3 Lenovo ThinkPad T580 Trackpad Replacement: step 6, image 2 of 3 Lenovo ThinkPad T580 Trackpad Replacement: step 6, image 3 of 3
    • Once all the clips are released, remove the bottom cover.
    • You may need to jiggle the case slightly to release the clips around the external battery bay.
    Ask FixBot
  7. Lenovo ThinkPad T580 Trackpad Replacement, Internal Battery: step 7, image 1 of 1
    • Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
    Ask FixBot
  8. Lenovo ThinkPad T580 Trackpad Replacement: step 8, image 1 of 3 Lenovo ThinkPad T580 Trackpad Replacement: step 8, image 2 of 3 Lenovo ThinkPad T580 Trackpad Replacement: step 8, image 3 of 3
    • Unplug and remove the battery connector from the motherboard.
    • Remove the internal battery.
    Ask FixBot
  9. Lenovo ThinkPad T580 Trackpad Replacement, Trackpad: step 9, image 1 of 2 Lenovo ThinkPad T580 Trackpad Replacement, Trackpad: step 9, image 2 of 2
    Tool used on this step:
    Halberd Spudger
    $2.99
    Buy
    Ask FixBot
  10. Lenovo ThinkPad T580 Trackpad Replacement: step 10, image 1 of 2 Lenovo ThinkPad T580 Trackpad Replacement: step 10, image 2 of 2
    • Using a Phillips #00 screwdriver, remove four 2.2 mm screws holding the trackpad.
    • Pull the trackpad out.
    Ask FixBot
Ben Elkayam
1,105 Reputation
8 Guides authored
Cal Poly, Team S18-G6, White Winter 2020 Member of Cal Poly, Team S18-G6, White Winter 2020
CPSU-WHITE-W20S18G6
4 Members
26 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 100
All Time: 5,800
