Lenovo ThinkPad T580 RAM Replacement
    1. Lenovo ThinkPad T580 RAM Replacement, External Battery: step 1, image 1 of 3 Lenovo ThinkPad T580 RAM Replacement, External Battery: step 1, image 2 of 3 Lenovo ThinkPad T580 RAM Replacement, External Battery: step 1, image 3 of 3
      • Slide the switch on the left side of the battery to the left.
      Ask FixBot
    2. Lenovo ThinkPad T580 RAM Replacement: step 2, image 1 of 3 Lenovo ThinkPad T580 RAM Replacement: step 2, image 2 of 3 Lenovo ThinkPad T580 RAM Replacement: step 2, image 3 of 3
      • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
      Ask FixBot
    3. Lenovo ThinkPad T580 RAM Replacement: step 3, image 1 of 3 Lenovo ThinkPad T580 RAM Replacement: step 3, image 2 of 3 Lenovo ThinkPad T580 RAM Replacement: step 3, image 3 of 3
      • Pull the battery directly out of the socket
      Ask FixBot
    1. Lenovo ThinkPad T580 RAM Replacement, Bottom Case: step 4, image 1 of 2 Lenovo ThinkPad T580 RAM Replacement, Bottom Case: step 4, image 2 of 2
      • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
      • The "captive" screws will not come out of the case.
      Ask FixBot
    2. Lenovo ThinkPad T580 RAM Replacement: step 5, image 1 of 3 Lenovo ThinkPad T580 RAM Replacement: step 5, image 2 of 3 Lenovo ThinkPad T580 RAM Replacement: step 5, image 3 of 3
      • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
      Ask FixBot
    3. Lenovo ThinkPad T580 RAM Replacement: step 6, image 1 of 3 Lenovo ThinkPad T580 RAM Replacement: step 6, image 2 of 3 Lenovo ThinkPad T580 RAM Replacement: step 6, image 3 of 3
      • Once all the clips are released, remove the bottom cover.
      • You may need to jiggle the case slightly to release the clips around the external battery bay.
      Ask FixBot
    1. Lenovo ThinkPad T580 RAM Replacement, Internal Battery: step 7, image 1 of 1
      • Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
      Ask FixBot
    2. Lenovo ThinkPad T580 RAM Replacement: step 8, image 1 of 3 Lenovo ThinkPad T580 RAM Replacement: step 8, image 2 of 3 Lenovo ThinkPad T580 RAM Replacement: step 8, image 3 of 3
      • Unplug and remove the battery connector from the motherboard.
      • Remove the internal battery.
      Ask FixBot
    1. Lenovo ThinkPad T580 RAM Replacement, RAM: step 9, image 1 of 3 Lenovo ThinkPad T580 RAM Replacement, RAM: step 9, image 2 of 3 Lenovo ThinkPad T580 RAM Replacement, RAM: step 9, image 3 of 3
      • Pull the two tabs on either side of the RAM card outwards with your fingers.
      Ask FixBot
    2. Lenovo ThinkPad T580 RAM Replacement: step 10, image 1 of 3 Lenovo ThinkPad T580 RAM Replacement: step 10, image 2 of 3 Lenovo ThinkPad T580 RAM Replacement: step 10, image 3 of 3
      • The RAM module should pop up to rest at an angle to the motherboard.
      • Pull the Wi-Fi card out from the port by the edges of the card.
      • Try to remove and insert the card at the same angle at which it rests with respect to the motherboard.
      Ask FixBot
    3. Lenovo ThinkPad T580 RAM Replacement: step 11, image 1 of 2 Lenovo ThinkPad T580 RAM Replacement: step 11, image 2 of 2
      • Remove the RAM module from the laptop.
      • Repeat the same process for the second RAM module if your computer included one.
      Ask FixBot
2 other people completed this guide.
Austin Blakely
23,332 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,713 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 135
All Time: 3,368
