Lenovo ThinkPad T580 Keyboard Replacement
Views: 9.5K
View statistics:
Past 24 Hours:
12
Past 7 Days:
54
Past 30 Days:
230
All Time:
9,460
Comments: 9
4 comments on steps, 5 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If the keyboard on your ThinkPad T580 stops working, you can use this repair guide to fix it. The keyboard is responsible for relaying the physical input from the user to the motherboard, so if it isn’t functioning properly it can prevent the owner from using the computer completely.
If your keyboard has malfunctioning keys, such as certain keys registering multiple presses when only pressed once, keys not registering presses at all, key chattering, or if your keyboard stops registering keypresses completely, replacing the keyboard should alleviate your problems.
Luckily, the keyboard in the ThinkPad T580 is modular and can be replaced from the front of the device. You don’t even need to open the back cover!
Parts
Tools
  • Jimmy
    $7.95
    4.9
  • Spudger
    4.9
    1. Lenovo ThinkPad T580 Keyboard Replacement, Unfasten the keyboard: step 1, image 1 of 1
      • Use a Phillips #00 screwdriver to unscrew the three 3.3 mm captive screws securing the keyboard.
      Ask FixBot
    2. Lenovo ThinkPad T580 Keyboard Replacement: step 2, image 1 of 3 Lenovo ThinkPad T580 Keyboard Replacement: step 2, image 2 of 3 Lenovo ThinkPad T580 Keyboard Replacement: step 2, image 3 of 3
      • Use a Jimmy to pry under the top left corner of the keyboard.
      • You may head a "click" or "pop" as the clips of the keyboard disengage.
      Ask FixBot
    3. Lenovo ThinkPad T580 Keyboard Replacement: step 3, image 1 of 3 Lenovo ThinkPad T580 Keyboard Replacement: step 3, image 2 of 3 Lenovo ThinkPad T580 Keyboard Replacement: step 3, image 3 of 3
      • Continue prying along the top edge of the keyboard, releasing the clips as you go.
      • Once the top edge has been fully released, grab the top edge and hinge the keyboard upwards on the bottom edge.
      Ask FixBot
    4. Lenovo ThinkPad T580 Keyboard Replacement: step 4, image 1 of 3 Lenovo ThinkPad T580 Keyboard Replacement: step 4, image 2 of 3 Lenovo ThinkPad T580 Keyboard Replacement: step 4, image 3 of 3
      • Pull the keyboard away from you, releasing the tabs along the bottom edge.
      • Be sure not to pull on the keyboard too excessively, as it is still connected to the motherboard via two ribbon cables.
      • Flip the keyboard over to rest face down over the trackpad.
      Ask FixBot
    5. Lenovo ThinkPad T580 Keyboard Replacement: step 5, image 1 of 3 Lenovo ThinkPad T580 Keyboard Replacement: step 5, image 2 of 3 Lenovo ThinkPad T580 Keyboard Replacement: step 5, image 3 of 3
      • Use a spudger to lift up the two black, hinged locking flaps on the ZIF connectors on the motherboard.
      Ask FixBot
    6. Lenovo ThinkPad T580 Keyboard Replacement: step 6, image 1 of 3 Lenovo ThinkPad T580 Keyboard Replacement: step 6, image 2 of 3 Lenovo ThinkPad T580 Keyboard Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of blunt nose tweezers to pull the two keyboard ribbon cables out from the ZIF connectors.
      Ask FixBot
    7. Lenovo ThinkPad T580 Keyboard Replacement: step 7, image 1 of 1
      • Remove the keyboard.
      Ask FixBot
3 other people completed this guide.
Austin Blakely
23,332 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
5 Guide Comments
Aren't there screws on the bottom of the laptop that ought to be unscrewed as well? That's what the T580 service guide says, I think.
Daniel Glus - Reply Share
This guide is wrong. You need to remove three screws on the bottom. Then slide the keyboard forward (towards the screen) and lift it up at the front to remove it.
Mart Conflin - Reply Share
This guide is indeed incorrect. After just pulling the screws out of the back of the keyboard thinking they were "clips" as stated in the article, I can confirm that you DO need to unscrew the three center screws on the back of the laptop prior to removing the keyboard.
Dave - Reply Share
Hi Dave.
You and the other commenters are 100% right! I have updated the guide accordingly.
Alex Diaz-Kokaisl - Reply Share
Is it possible to replace the non-backlit keyboard into backlit one?
Ahmad Naufal Firdaus - Reply Share
Past 24 Hours: 12
Past 7 Days: 54
Past 30 Days: 230
All Time: 9,460
