Introduction
Go to step 1 ↓If the fingerprint sensor on your Lenovo ThinkPad T580 computer breaks, stops working, or sustains damage, you can use this step-by-step repair guide to fix it! The fingerprint sensor is used to secure the device with a physical key (your fingerprint) rather than a digital one like a password. If the fingerprint sensor breaks or stops registering your fingerprint, you may find yourself locked out of your computer, which can be a nuisance.
Replacing the fingerprint sensor should allow you to continue using your fingerprint to unlock your computer, although you may need to register your fingerprint with the new board after replacing it. If this is the case, you’ll need to remember your digital password to unlock the computer and re-register those fingerprints to the new sensor.
Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
Using a spudger, flip up the black tab of the fingerprint sensor's ZIF connector on the motherboard.
