Lenovo ThinkPad T580 CMOS Battery Replacement
    1. Lenovo ThinkPad T580 CMOS Battery Replacement, External Battery: step 1, image 1 of 3 Lenovo ThinkPad T580 CMOS Battery Replacement, External Battery: step 1, image 2 of 3 Lenovo ThinkPad T580 CMOS Battery Replacement, External Battery: step 1, image 3 of 3
      • Slide the switch on the left side of the battery to the left.
      Ask FixBot
    2. Lenovo ThinkPad T580 CMOS Battery Replacement: step 2, image 1 of 3 Lenovo ThinkPad T580 CMOS Battery Replacement: step 2, image 2 of 3 Lenovo ThinkPad T580 CMOS Battery Replacement: step 2, image 3 of 3
      • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
      Ask FixBot
    3. Lenovo ThinkPad T580 CMOS Battery Replacement: step 3, image 1 of 3 Lenovo ThinkPad T580 CMOS Battery Replacement: step 3, image 2 of 3 Lenovo ThinkPad T580 CMOS Battery Replacement: step 3, image 3 of 3
      • Pull the battery directly out of the socket
      Ask FixBot
    1. Lenovo ThinkPad T580 CMOS Battery Replacement, Bottom Case: step 4, image 1 of 2 Lenovo ThinkPad T580 CMOS Battery Replacement, Bottom Case: step 4, image 2 of 2
      • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
      • The "captive" screws will not come out of the case.
      Ask FixBot
    2. Lenovo ThinkPad T580 CMOS Battery Replacement: step 5, image 1 of 3 Lenovo ThinkPad T580 CMOS Battery Replacement: step 5, image 2 of 3 Lenovo ThinkPad T580 CMOS Battery Replacement: step 5, image 3 of 3
      • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
      Ask FixBot
    3. Lenovo ThinkPad T580 CMOS Battery Replacement: step 6, image 1 of 3 Lenovo ThinkPad T580 CMOS Battery Replacement: step 6, image 2 of 3 Lenovo ThinkPad T580 CMOS Battery Replacement: step 6, image 3 of 3
      • Once all the clips are released, remove the bottom cover.
      • You may need to jiggle the case slightly to release the clips around the external battery bay.
      Ask FixBot
    1. Lenovo ThinkPad T580 CMOS Battery Replacement, Internal Battery: step 7, image 1 of 1
      • Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
      Ask FixBot
    2. Lenovo ThinkPad T580 CMOS Battery Replacement: step 8, image 1 of 3 Lenovo ThinkPad T580 CMOS Battery Replacement: step 8, image 2 of 3 Lenovo ThinkPad T580 CMOS Battery Replacement: step 8, image 3 of 3
      • Unplug and remove the battery connector from the motherboard.
      • Remove the internal battery.
      Ask FixBot
    1. Lenovo ThinkPad T580 CMOS Battery Replacement, CMOS Battery: step 9, image 1 of 3 Lenovo ThinkPad T580 CMOS Battery Replacement, CMOS Battery: step 9, image 2 of 3 Lenovo ThinkPad T580 CMOS Battery Replacement, CMOS Battery: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Pull out the CMOS battery cable connector with a pair of blunt nose tweezers.
      Ask FixBot
    2. Lenovo ThinkPad T580 CMOS Battery Replacement: step 10, image 1 of 3 Lenovo ThinkPad T580 CMOS Battery Replacement: step 10, image 2 of 3 Lenovo ThinkPad T580 CMOS Battery Replacement: step 10, image 3 of 3
      • Using a spudger, pry the CMOS battery off of the motherboard.
      • A light adhesive holds the CMOS battery down to the motherboard. Be careful not to puncture the battery while prying it off.
      • Remove the CMOS battery.
      Ask FixBot
Austin Blakely
23,173 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
123 Members
77,712 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 61
All Time: 2,313
