Lenovo ThinkPad T570 Webcam Replacement
    1. Lenovo ThinkPad T570 Webcam Replacement, Webcam: step 1, image 1 of 1
      • Insert the plastic opening tool between the screen and the bezel around the screen.
      • Gently pry along the top edges to loosen the frame clips.
      • Slide the tool along the entire top and bottom edge until the bezel around the display is free.
      • Remove the bezel and set it aside.
      Ask FixBot
    2. Lenovo ThinkPad T570 Webcam Replacement: step 2, image 1 of 1
      • Tilt the screen forward to access the area behind the display.
      • If needed, gently pull the display cable connector straight out to disconnect it from the back of the screen. Disconnecting the display cable is optional. If you leave it connected, just ensure there’s no strain or pressure on the cable while you work.
      • Set the screen aside or hold it at an angle that gives you access to the webcam at the top edge.
      Ask FixBot
    3. Lenovo ThinkPad T570 Webcam Replacement: step 3, image 1 of 3 Lenovo ThinkPad T570 Webcam Replacement: step 3, image 2 of 3 Lenovo ThinkPad T570 Webcam Replacement: step 3, image 3 of 3
      • Use the plastic opening tool to lift the webcam from the top edge of the screen.
      • The webcam may be slightly adhered; pry gently to avoid damage.
      • Once free, pull the cable to disconnect from the back of the webcam.
      • Lift the webcam out of the space.
      Ask FixBot
Mauricio Harp
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 26
All Time: 240
