Lenovo ThinkPad T560 SSD/Hard Drive Replacement
    1. Lenovo ThinkPad T560 SSD/Hard Drive Replacement, Back Panel: step 1, image 1 of 1
      • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
      • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
      • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
      Ask FixBot
    2. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: step 2, image 1 of 1
      • Use the iFixit opening tool to pry the back panel off your T560.
      • Work your way around the perimeter of the device to undo the clips and detach the back panel.
      Ask FixBot
    1. Lenovo ThinkPad T560 SSD/Hard Drive Replacement, SSD/Hard Drive: step 3, image 1 of 1
      • Using the Phillips #0 screwdriver, remove the 3.5mm screw securing the SSD/Hard Drive.
      Ask FixBot
    2. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: step 4, image 1 of 1
      • Pick up the SSD/Hard Drive and unplug it from the cable connecting the SSD/Hard Drive to the motherboard.
      Ask FixBot
    3. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: step 5, image 1 of 1
      • Remove SSD/Hard Drive case from the drive.
      Ask FixBot
2 other people completed this guide.
Jackson Reynolds
517 Reputation
5 Guides authored
Clemson, Team 1-3, Hunter Spring 2022 Member of Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 Members
59 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 111
All Time: 8,214
