Lenovo ThinkPad T560 Battery Replacement
Views: 6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
40
Past 30 Days:
170
All Time:
6,009
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
If the internal battery for your Lenovo Thinkpad T560 has gone bad and needs to be replaced, follow this guide. Note that the Lenovo Thinkpad T560 has two batteries: an internal battery and an external battery.
The most common reasons to why this component needs to be replaced are:
  • The battery is failing to charge effectively
  • The internal/external battery has gone bad
Before replacing the battery, make sure to power down the device and disconnect it from any external power sources.
Tools
    1. Lenovo ThinkPad T560 Battery Replacement, Back Panel: step 1, image 1 of 1
      • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
      • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
      • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
      Ask FixBot
    2. Lenovo ThinkPad T560 Battery Replacement: step 2, image 1 of 1
      • Use the iFixit opening tool to pry the back panel off your T560.
      • Work your way around the perimeter of the device to undo the clips and detach the back panel.
      Ask FixBot
    1. Lenovo ThinkPad T560 Battery Replacement, Battery: step 3, image 1 of 2 Lenovo ThinkPad T560 Battery Replacement, Battery: step 3, image 2 of 2
      • Disconnect the battery connector from the motherboard by pulling it out of the port.
      Ask FixBot
    2. Lenovo ThinkPad T560 Battery Replacement: step 4, image 1 of 1
      • Using the Phillips #0 screwdriver, remove the five 3.5 mm screws securing the battery.
      • Remove the battery.
      Ask FixBot
Jackson Reynolds
517 Reputation
5 Guides authored
Clemson, Team 1-3, Hunter Spring 2022 Member of Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 Members
60 Guides authored
1 Guide Comment
Is there any way to disable the battery whitelist or otherwise get the device to work with 'unauthorized' external batteries as OEM external batteries are no longer produced by Lenovo or sold by any vendor including ifixit itself? I've had some that worked for close to a year now up until yesterday, when the laptop suddenly decided they are no longer official.
David L. - Reply Share
Past 24 Hours: 3
Past 7 Days: 40
Past 30 Days: 170
All Time: 6,009
