Lenovo ThinkPad T540P RAM Replacement
    1. Lenovo ThinkPad T540P RAM Replacement, Battery: step 1, image 1 of 2 Lenovo ThinkPad T540P RAM Replacement, Battery: step 1, image 2 of 2
      • Before proceeding, power down the laptop and unplug the device from the power supply / charger.
      • Flip the laptop over so the bottom is showing.
      • Orient the laptop so that the the battery bump is facing away from you.
      Ask FixBot
    2. Lenovo ThinkPad T540P RAM Replacement: step 2, image 1 of 1
      • On the back of the laptop are two sliding locks for the battery. These are located just beneath the battery and are marked with a little lock icon on either end.
      • Using both hands, pull these sliding locks away from each other.
      • They will stay in place once they have been fully engaged.
      Ask FixBot
    3. Lenovo ThinkPad T540P RAM Replacement: step 3, image 1 of 2 Lenovo ThinkPad T540P RAM Replacement: step 3, image 2 of 2
      • Push the battery in the direction away from where the sliding tabs are.
      • If the battery does not slide out, make sure the sliding locks are fully engaged.
      • To install a new battery, slide the battery back in with the sticker side of the battery facing down, and in the same orientation that it came out in.
      Ask FixBot
    1. Lenovo ThinkPad T540P RAM Replacement, RAM: step 4, image 1 of 2 Lenovo ThinkPad T540P RAM Replacement, RAM: step 4, image 2 of 2
      • Loosen the two M2 x 5 mm captive screws on the large back panel with a Phillips #1 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad T540P RAM Replacement: step 5, image 1 of 1
      • Locate the two RAM sticks and the latches holding them in place.
      Ask FixBot
    3. Lenovo ThinkPad T540P RAM Replacement: step 6, image 1 of 1
      • There are two populated RAM slots on this laptop, so you will have to do steps 6 and 7 twice.
      • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      Ask FixBot
    4. Lenovo ThinkPad T540P RAM Replacement: step 7, image 1 of 1
      • Pull the RAM module directly out of its socket from the same angle.
      • To reinstall a RAM module, line up the RAM stick’s groove with the notch in the slot, and insert the stick at a 45° angle. Then push down until clamps click into place.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 97
All Time: 515
