Lenovo ThinkPad T540P CMOS Battery Replacement
  1. Lenovo ThinkPad T540P CMOS Battery Replacement, Battery: step 1, image 1 of 2 Lenovo ThinkPad T540P CMOS Battery Replacement, Battery: step 1, image 2 of 2
    • Before proceeding, power down the laptop and unplug the device from the power supply / charger.
    • Flip the laptop over so the bottom is showing.
    • Orient the laptop so that the the battery bump is facing away from you.
    Ask FixBot
  2. Lenovo ThinkPad T540P CMOS Battery Replacement: step 2, image 1 of 1
    • On the back of the laptop are two sliding locks for the battery. These are located just beneath the battery and are marked with a little lock icon on either end.
    • Using both hands, pull these sliding locks away from each other.
    • They will stay in place once they have been fully engaged.
    Ask FixBot
  3. Lenovo ThinkPad T540P CMOS Battery Replacement: step 3, image 1 of 2 Lenovo ThinkPad T540P CMOS Battery Replacement: step 3, image 2 of 2
    • Push the battery in the direction away from where the sliding tabs are.
    • If the battery does not slide out, make sure the sliding locks are fully engaged.
    • To install a new battery, slide the battery back in with the sticker side of the battery facing down, and in the same orientation that it came out in.
    Ask FixBot
  4. Lenovo ThinkPad T540P CMOS Battery Replacement, CMOS Battery: step 4, image 1 of 2 Lenovo ThinkPad T540P CMOS Battery Replacement, CMOS Battery: step 4, image 2 of 2
    • The screw in this panel is captive, so it will not come loose from the panel.
    • Using a Phillips #1 screwdriver, unscrew the one M2 x 5mm screw holding the CMOS battery door in place.
    Ask FixBot
  5. Lenovo ThinkPad T540P CMOS Battery Replacement: step 5, image 1 of 1
    • Using an opening pick or your fingernail, work your way around the edges of the panel popping the clips off that hold the panel in place.
    Ask FixBot
  6. Lenovo ThinkPad T540P CMOS Battery Replacement: step 6, image 1 of 1
    • Locate the CMOS battery and its connector.
    Ask FixBot
  7. Lenovo ThinkPad T540P CMOS Battery Replacement: step 7, image 1 of 2 Lenovo ThinkPad T540P CMOS Battery Replacement: step 7, image 2 of 2
    • Gently unplug the CMOS battery from of motherboard.
    • Remove the CMOS battery.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 11
Past 30 Days: 44
All Time: 257
