Lenovo ThinkPad T530 Keyboard Replacement
    1. Lenovo ThinkPad T530 Keyboard Replacement, Place your laptop upside down: step 1, image 1 of 2 Lenovo ThinkPad T530 Keyboard Replacement, Place your laptop upside down: step 1, image 2 of 2
      • Ensure that the laptop is disconnected from the wall charger, and that the laptop is entirely powered off before following any of the steps below.
      • Flip your laptop upside down, so that the keyboard is facing down.
      Ask FixBot
    2. Lenovo ThinkPad T530 Keyboard Replacement, Unlock Battery: step 2, image 1 of 2 Lenovo ThinkPad T530 Keyboard Replacement, Unlock Battery: step 2, image 2 of 2
      • Locate the latch located on the battery near the top of the laptop.
      • Using your finger, slide the latch to the right-most (Unlocked) position.
      • None of this should require an exhuberant amount of force.
      Ask FixBot
    3. Lenovo ThinkPad T530 Keyboard Replacement, Remove the Battery: step 3, image 1 of 2 Lenovo ThinkPad T530 Keyboard Replacement, Remove the Battery: step 3, image 2 of 2
      • You can now pull the battery away from the laptop. When pulling the battery out, ensure to pull it out straight.
      Ask FixBot
    1. Lenovo ThinkPad T530 Keyboard Replacement, Removing bottom screws: step 4, image 1 of 2 Lenovo ThinkPad T530 Keyboard Replacement, Removing bottom screws: step 4, image 2 of 2
      • Using a Phillips #00 screwdriver, unscrew the following screws, and then remove the cover.
      • Using a Phillips #00 screwdriver, remove the screw. This is one of the two screws that are holding in the keyboard.
      Ask FixBot
    2. Lenovo ThinkPad T530 Keyboard Replacement, Removing bottom screws (Continued): step 5, image 1 of 1
      • Using a Phillips #00 screwdriver, unscrew the highlighted screw. This is the last screw securing the keyboard to the laptop.
      Ask FixBot
    3. Lenovo ThinkPad T530 Keyboard Replacement, Revealing the Keyboard: step 6, image 1 of 2 Lenovo ThinkPad T530 Keyboard Replacement, Revealing the Keyboard: step 6, image 2 of 2
      • Flip the laptop right-side up, with the keyboard facing towards you.
      • Open the laptop.
      Ask FixBot
    4. Lenovo ThinkPad T530 Keyboard Replacement, Removing the Keyboard: step 7, image 1 of 3 Lenovo ThinkPad T530 Keyboard Replacement, Removing the Keyboard: step 7, image 2 of 3 Lenovo ThinkPad T530 Keyboard Replacement, Removing the Keyboard: step 7, image 3 of 3
      • Place each of your two thumbs on the bottom-left and right most corners of the keyboard (towards the arrow keys, and the Fn (Function) key).
      • Gentilly and slowly push the keyboard up (towards the display)
      • Lift the two corners of the keyboard up enough to see the ribbon cable below.
      • Applying excessive force to the keyboard ribbon connector may result in damage to the system.
      Ask FixBot
    5. Lenovo ThinkPad T530 Keyboard Replacement, Disconnecting the Ribon Cable: step 8, image 1 of 3 Lenovo ThinkPad T530 Keyboard Replacement, Disconnecting the Ribon Cable: step 8, image 2 of 3 Lenovo ThinkPad T530 Keyboard Replacement, Disconnecting the Ribon Cable: step 8, image 3 of 3
      • Angle the keyboard upwards, at a 90° angle.
      • Keep one finger holding the keyboard up, while using the other to disconnect the ribbon cable. To disconnect the ribbon cable, lift it up by the highlighted yellow end.
      Ask FixBot
    6. Lenovo ThinkPad T530 Keyboard Replacement, Taking out the Keyboard: step 9, image 1 of 1
      • The keyboard is now disconnected from the laptop, and you can remove it and place it aside.
      Ask FixBot
    7. Lenovo ThinkPad T530 Keyboard Replacement, Reconnecting the Ribbon Cable: step 10, image 1 of 1
      • Reconnect the keyboard ribbon cable by pushing it down onto the slot.
      Ask FixBot
    8. Lenovo ThinkPad T530 Keyboard Replacement, Reinstalling the Keyboard: step 11, image 1 of 3 Lenovo ThinkPad T530 Keyboard Replacement, Reinstalling the Keyboard: step 11, image 2 of 3 Lenovo ThinkPad T530 Keyboard Replacement, Reinstalling the Keyboard: step 11, image 3 of 3
      • Guide the keyboards top edge underneath the frame.
      • 2nd Image was copied from the Lenovo T530/T530i/W530 Service Manual.
      Ask FixBot
    9. Lenovo ThinkPad T530 Keyboard Replacement, Reseating the Keyboard: step 12, image 1 of 2 Lenovo ThinkPad T530 Keyboard Replacement, Reseating the Keyboard: step 12, image 2 of 2
      • Push the keyboard down, then pull it back towards your trackpad.
      Ask FixBot
    10. Lenovo ThinkPad T530 Keyboard Replacement, Reinstalling Screws: step 13, image 1 of 1
      • Using a Phillips #00 screwdriver, re-screw the highlighted screws.
      Ask FixBot
    11. Lenovo ThinkPad T530 Keyboard Replacement, Reinstalling Bottom Cover: step 14, image 1 of 3 Lenovo ThinkPad T530 Keyboard Replacement, Reinstalling Bottom Cover: step 14, image 2 of 3 Lenovo ThinkPad T530 Keyboard Replacement, Reinstalling Bottom Cover: step 14, image 3 of 3
      • Reinsert the bottom memory cover, ensuring all clips are in place.
      • Using a Phillips #00 tighten the two highlighted screws.
      Ask FixBot
You're now done replacing your Lenovo T530's Keyboard all by yourself, great work!
Attached Documents
Albert Stoynov
1,430 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 103
All Time: 1,498
