Introduction
I will be showing you how to replace the HDD/SSD on the ThinkPad T520.
Using your fingers, slide the lock to the unlocked position.
Then remove the battery from the slot.
Remove the single screw holding in the plastic cover.
Remove the plastic cover from the laptop.
Using your fingers pull on the black plastic tab.
Remove the HDD/SSD from the laptop.
