Lenovo ThinkPad T500 Screen Replacement
    1. Lenovo ThinkPad T500 Screen Replacement, Screen: step 1, image 1 of 1
      • Remove the eight 14mm screws using the Phillips #0 Screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad T500 Screen Replacement: step 2, image 1 of 1
      • Lift the palm rest panel up.
      • Be sure to lift the panel slowly; there is a ribbon cable attached to the bottom.
      Ask FixBot
    3. Lenovo ThinkPad T500 Screen Replacement: step 3, image 1 of 1
      • Use the spudger to disconnect the ribbon cable.
      Ask FixBot
    4. Lenovo ThinkPad T500 Screen Replacement: step 4, image 1 of 1
      • With the panel disconnected, lift the keyboard.
      • As with the panel, lift the keyboard slowly; there is a ribbon cable attached to the bottom.
      Ask FixBot
    5. Lenovo ThinkPad T500 Screen Replacement: step 5, image 1 of 1
      • Disconnect the ribbon cable with the spudger.
      Ask FixBot
    6. Lenovo ThinkPad T500 Screen Replacement: step 6, image 1 of 2 Lenovo ThinkPad T500 Screen Replacement: step 6, image 2 of 2
      • Remove the keyboard and the panel.
      • Using the Phillips #0 Screwdriver, remove the three 3 mm screws that are at the bottom sides and near the top-left of the speaker cover.
      • Disconnect the orange and blue cables next to the left side of the speaker cover.
      Ask FixBot
    7. Lenovo ThinkPad T500 Screen Replacement: step 7, image 1 of 1
      • Remove the speaker cover.
      Ask FixBot
    8. Lenovo ThinkPad T500 Screen Replacement: step 8, image 1 of 1
      • Remove the two 3mm screws on the left speaker with the Phillips #0 Screwdriver.
      Ask FixBot
    9. Lenovo ThinkPad T500 Screen Replacement: step 9, image 1 of 2 Lenovo ThinkPad T500 Screen Replacement: step 9, image 2 of 2
      • Detach the blue and orange cables from the left speaker's clamps.
      Ask FixBot
    10. Lenovo ThinkPad T500 Screen Replacement: step 10, image 1 of 2 Lenovo ThinkPad T500 Screen Replacement: step 10, image 2 of 2
      • Using the Phillips #0 Screwdriver, lift the metal fastener up and remove the black and white wires.
      Ask FixBot
    11. Lenovo ThinkPad T500 Screen Replacement: step 11, image 1 of 2 Lenovo ThinkPad T500 Screen Replacement: step 11, image 2 of 2
      • Remove the two 3mm screws next to the lid hinges, as well as the two 3mm screws on the lid's ribbon cable.
      Ask FixBot
    12. Lenovo ThinkPad T500 Screen Replacement: step 12, image 1 of 1
      • Use the spudger to detach the screen's ribbon cable.
      Ask FixBot
    13. Lenovo ThinkPad T500 Screen Replacement: step 13, image 1 of 1
      • Remove the screen.
      Ask FixBot
8 other people completed this guide.
nicO
15,990 Reputation
88 Guides authored
1 Guide Comment
It was of good help, but be aware that you need to remove two screws on the back before removing the speaker cover. If not you will break the cover.
Bjørnar Valand - Reply Share
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 130
All Time: 5,924
