Lenovo ThinkPad T495s Trackpad Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
101
All Time:
2,480
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If you need to replace the trackpad of your Lenovo ThinkPad T495s, follow the steps in the guide below. Be aware that you will need to remove the battery before the trackpad. The trackpad does the same job as a mouse on a desktop computer does. You use the trackpad to control the mouse pointer that is displayed on the laptop screen.
Parts
Tools
    1. Lenovo ThinkPad T495s Trackpad Replacement, Back Panel: step 1, image 1 of 1
      • Do not begin until the laptop is unplugged and completely powered off.
      • Flip the laptop over to reveal the back panel of the laptop.
      Ask FixBot
    2. Lenovo ThinkPad T495s Trackpad Replacement: step 2, image 1 of 3 Lenovo ThinkPad T495s Trackpad Replacement: step 2, image 2 of 3 Lenovo ThinkPad T495s Trackpad Replacement: step 2, image 3 of 3
      • Loosen the five 4.0 mm captive screws with a Phillips #1 screwdriver.
      • The screws will stay attached to the back cover as you lift it off.
      Ask FixBot
    1. Lenovo ThinkPad T495s Trackpad Replacement, Battery: step 3, image 1 of 3 Lenovo ThinkPad T495s Trackpad Replacement, Battery: step 3, image 2 of 3 Lenovo ThinkPad T495s Trackpad Replacement, Battery: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to unplug the battery connection from the motherboard.
      Ask FixBot
    2. Lenovo ThinkPad T495s Trackpad Replacement: step 4, image 1 of 3 Lenovo ThinkPad T495s Trackpad Replacement: step 4, image 2 of 3 Lenovo ThinkPad T495s Trackpad Replacement: step 4, image 3 of 3
      • Remove the five 4.5 mm screws with a Phillips #1 screwdriver.
      • There are plastic tabs at the bottom of the battery, so pull it slightly forward with your hands, toward the motherboard, before lifting straight up.
      Ask FixBot
    1. Lenovo ThinkPad T495s Trackpad Replacement, Trackpad: step 5, image 1 of 3 Lenovo ThinkPad T495s Trackpad Replacement, Trackpad: step 5, image 2 of 3 Lenovo ThinkPad T495s Trackpad Replacement, Trackpad: step 5, image 3 of 3
      • Use the iFixit Opening Tool to flip up the small locking flap on the trackpad's one ZIF ribbon cable connection. The ribbon cable should easily release from its socket.
      • ZIF stands for Zero Insertion Force; if you're experiencing any resistance whatsoever during disconnection, double-check that the locking flaps are flipped up.
      Ask FixBot
    2. Lenovo ThinkPad T495s Trackpad Replacement: step 6, image 1 of 3 Lenovo ThinkPad T495s Trackpad Replacement: step 6, image 2 of 3 Lenovo ThinkPad T495s Trackpad Replacement: step 6, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the four 2.2 mm screws from the trackpad.
      Ask FixBot
    3. Lenovo ThinkPad T495s Trackpad Replacement: step 7, image 1 of 3 Lenovo ThinkPad T495s Trackpad Replacement: step 7, image 2 of 3 Lenovo ThinkPad T495s Trackpad Replacement: step 7, image 3 of 3
      • With the bottom of the laptop facing you, gently lift the laptop open until the trackpad drops out.
      Ask FixBot
Jessica Costa
131 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 101
All Time: 2,480
