Lenovo ThinkPad T495s Fan Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
93
All Time:
1,704
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If you're noticing that your Lenovo ThinkPad T495s is running noticeably hotter than it used to, or you're experiencing seemingly random shutdowns while running hardware-intensive applications, there's a good chance that your fan is either too dirty to disperse heat efficiently, or has died altogether.
Before replacing your fan, take a look at the blades. If you can see a noticeable build-up of gunk, try thoroughly cleaning the blades with a combination of an ESD-safe brush and compressed air. If cleaning the blades doesn't help your fan's performance, or if the blades aren't spinning whatsoever while the computer is on, it's probably time to replace the fan.
Parts
Tools
    1. Lenovo ThinkPad T495s Fan Replacement, Back Panel: step 1, image 1 of 1
      • Do not begin until the laptop is unplugged and completely powered off.
      • Flip the laptop over to reveal the back panel of the laptop.
      Ask FixBot
    2. Lenovo ThinkPad T495s Fan Replacement: step 2, image 1 of 3 Lenovo ThinkPad T495s Fan Replacement: step 2, image 2 of 3 Lenovo ThinkPad T495s Fan Replacement: step 2, image 3 of 3
      • Loosen the five 4.0 mm captive screws with a Phillips #1 screwdriver.
      • The screws will stay attached to the back cover as you lift it off.
      Ask FixBot
    1. Lenovo ThinkPad T495s Fan Replacement, Fan: step 3, image 1 of 3 Lenovo ThinkPad T495s Fan Replacement, Fan: step 3, image 2 of 3 Lenovo ThinkPad T495s Fan Replacement, Fan: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Use a Phillips #1 screwdriver to loosen the four 2.2 mm captive screws from the fan assembly.
      • The screws should stay attached to the fan during removal.
      • Use tweezers to unplug the fan assembly from the motherboard.
      • Lift the fan from the laptop using your hands.
      Ask FixBot
Connor Bassolino
26,171 Reputation
125 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 93
All Time: 1,704
