Parts
Tools
Introduction
Go to step 1 ↓When a blue screen occurs on your Lenovo ThinkPad T495, an error code will appear somewhere on the screen, as well as a scannable QR code which can be used to diagnose what is wrong with your device. In the case of this guide, the lack of memory or faulty memory will be covered, and the stick of RAM will be replaced.
6 other people completed this guide.
2 Guide Comments
Hi, can we disable the onboard RAM from BIOS or any tool from the OS?
Big problem here. You cannot remove the RAM that comes with the laptop. The instructions above say "Use your fingers to gently pull the two arms on each side horizontally until the RAM springs up." No, the RAM does not spring up on my T495 because it is soldered! By the time I realized that, I had nearly broken one of the RAM-holding arms. The T495 comes with two RAM slots. On my laptop, one slot had an 8 GM RAM module that came with the laptop. After realizing it cannot be removed, I put in a new 16 GB RAM module on top of the old one. The new module is now held in place by only one of the arms. The other one is dislocated because of the fool I was in trying to pull the arm until the old RAM sprang up. It is soldered, as I learned the hard way.
