Lenovo ThinkPad T490 Touchpad Replacement
    1. Lenovo ThinkPad T490 Touchpad Replacement, Base Plate: step 1, image 1 of 1
      • Loosen the screws from the base plate.
      • Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
      • These screws are captive - they will not fully come out after being unscrewed.
      Ask FixBot
    2. Lenovo ThinkPad T490 Touchpad Replacement: step 2, image 1 of 1
      • Insert the iFixit opening tool into the space between the base plate and the chassis.
      • Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
      Ask FixBot
    3. Lenovo ThinkPad T490 Touchpad Replacement: step 3, image 1 of 1
      • Grab the edge of the cover and lift the cover away from you.
      • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
      Ask FixBot
    1. Lenovo ThinkPad T490 Touchpad Replacement, Battery: step 4, image 1 of 3 Lenovo ThinkPad T490 Touchpad Replacement, Battery: step 4, image 2 of 3 Lenovo ThinkPad T490 Touchpad Replacement, Battery: step 4, image 3 of 3
      • Before beginning, be sure to boot into BIOS and disable the built-in battery.
      • Remove the four 3 mm screws securing the battery with a Phillips #00 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad T490 Touchpad Replacement: step 5, image 1 of 1
      • Use tweezers or your fingernails to disconnect the battery from its motherboard socket.
      Ask FixBot
    3. Lenovo ThinkPad T490 Touchpad Replacement: step 6, image 1 of 1
      • Lift up and remove the battery from the device.
      Ask FixBot
    1. Lenovo ThinkPad T490 Touchpad Replacement, Touchpad: step 7, image 1 of 3 Lenovo ThinkPad T490 Touchpad Replacement, Touchpad: step 7, image 2 of 3 Lenovo ThinkPad T490 Touchpad Replacement, Touchpad: step 7, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the four screws securing the touchpad.
      Ask FixBot
    2. Lenovo ThinkPad T490 Touchpad Replacement: step 8, image 1 of 1
      • Use a pair of tweezers to flip up the black locking flap securing the touchpad ribbon cable.
      • Disconnect the ribbon cable.
      Ask FixBot
    3. Lenovo ThinkPad T490 Touchpad Replacement: step 9, image 1 of 1
      • Carefully lift the laptop's base from the monitor. The touchpad will be left on the computer's screen.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Bryce Scholten
277 Reputation
2 Guides authored
UW Tacoma, Team E-6, Rose Fall 2025 Member of UW Tacoma, Team E-6, Rose Fall 2025
UWT-ROSE-F25SEG6
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 40
Past 30 Days: 172
All Time: 973
