Lenovo ThinkPad T490 RAM Replacement
    1. Lenovo ThinkPad T490 RAM Replacement, Unscrew the base plate: step 1, image 1 of 1
      • Remove the screws from the base plate using a Phillips #00 screwdriver to access the motherboard.
      Ask FixBot
    2. Lenovo ThinkPad T490 RAM Replacement, Pry the base plate off: step 2, image 1 of 2 Lenovo ThinkPad T490 RAM Replacement, Pry the base plate off: step 2, image 2 of 2
      • Once the screws are off, gently fit the iFixit Opening Tool under the base plate to pry it open.
      • Fully remove the base plate so you can access the RAM.
      Ask FixBot
    3. Lenovo ThinkPad T490 RAM Replacement, Locate components: step 3, image 1 of 1
      • Locate the RAM module.
      • Locate the laptop's battery cable.
      Ask FixBot
    4. Lenovo ThinkPad T490 RAM Replacement, Disconnect the battery: step 4, image 1 of 2 Lenovo ThinkPad T490 RAM Replacement, Disconnect the battery: step 4, image 2 of 2
      • To disconnect the battery, tug the black tab away from the socket as shown. This will separate the connector from the socket.
      • Be cautious when handling any batteries. A punctured or damaged battery is a fire risk and should be disposed of immediately.
      • This step helps with the reinstallation process.
      Ask FixBot
    5. Lenovo ThinkPad T490 RAM Replacement, Remove the RAM stick: step 5, image 1 of 2 Lenovo ThinkPad T490 RAM Replacement, Remove the RAM stick: step 5, image 2 of 2
      • Flip up the black flap that is covering the RAM stick.
      • Once the black flap is out of the way, hold the RAM stick on both sides and gently pull directly backward to remove it from its slot.
      • Slide the replacement RAM stick in and place the black flap back over it to begin reassembling your device.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 71
Past 30 Days: 304
All Time: 4,667
