Lenovo ThinkPad T490 CMOS Battery Replacement
    1. Lenovo ThinkPad T490 CMOS Battery Replacement, CMOS Battery: step 1, image 1 of 1
      • Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
      • These screws are captive - they will not fully come out after being unscrewed.
      Ask FixBot
    2. Lenovo ThinkPad T490 CMOS Battery Replacement: step 2, image 1 of 1
      • Insert the iFixit opening tool into the space between the baseplate and the chassis.
      • Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
      Ask FixBot
    3. Lenovo ThinkPad T490 CMOS Battery Replacement: step 3, image 1 of 1
      • Grab the edge of the cover and lift the cover away from you.
      • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
      Ask FixBot
    4. Lenovo ThinkPad T490 CMOS Battery Replacement: step 4, image 1 of 2 Lenovo ThinkPad T490 CMOS Battery Replacement: step 4, image 2 of 2
      • Locate the battery socket connector parallel to the motherboard.
      • Slide the battery socket connector out of its socket on the motherboard.
      Ask FixBot
    5. Lenovo ThinkPad T490 CMOS Battery Replacement: step 5, image 1 of 2 Lenovo ThinkPad T490 CMOS Battery Replacement: step 5, image 2 of 2
      • Unplug the connector from the socket on the motherboard.
      • Pry the coin cell battery off of the motherboard.
      Ask FixBot
    6. Lenovo ThinkPad T490 CMOS Battery Replacement: step 6, image 1 of 1
      • Insert new coin cell battery.
      Ask FixBot
2 Guide Comments
I read in a Lenovo "how to" video that you should go into the BIOS and disable the CMOS battery before replacing.
Jaimo - Reply Share
could you confirm the part name for the battery?
Mathew Owens - Reply Share
Past 24 Hours: 6
Past 7 Days: 34
Past 30 Days: 153
All Time: 3,678
