Lenovo ThinkPad T480s USB Card Replacement
    1. Lenovo ThinkPad T480s USB Card Replacement, Bottom Cover: step 1, image 1 of 2 Lenovo ThinkPad T480s USB Card Replacement, Bottom Cover: step 1, image 2 of 2
      • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
      • Loosen the six captive screws with a Phillips #1 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad T480s USB Card Replacement: step 2, image 1 of 3 Lenovo ThinkPad T480s USB Card Replacement: step 2, image 2 of 3 Lenovo ThinkPad T480s USB Card Replacement: step 2, image 3 of 3
      • Remove the bottom cover with an opening tool.
      • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
      Ask FixBot
    3. Lenovo ThinkPad T480s USB Card Replacement: step 3, image 1 of 2 Lenovo ThinkPad T480s USB Card Replacement: step 3, image 2 of 2
      • Lift the bottom cover off.
      Ask FixBot
    1. Lenovo ThinkPad T480s USB Card Replacement, Fan Assembly: step 4, image 1 of 2 Lenovo ThinkPad T480s USB Card Replacement, Fan Assembly: step 4, image 2 of 2
      • Use the spudger to disconnect the fan cable from the motherboard.
      Ask FixBot
    2. Lenovo ThinkPad T480s USB Card Replacement: step 5, image 1 of 2 Lenovo ThinkPad T480s USB Card Replacement: step 5, image 2 of 2
      • Loosen the four captive screws attaching the fan assembly to the motherboard.
      • Do not attempt to remove the captive screws, as forcing them out may strip or damage them.
      Ask FixBot
    3. Lenovo ThinkPad T480s USB Card Replacement: step 6, image 1 of 3 Lenovo ThinkPad T480s USB Card Replacement: step 6, image 2 of 3 Lenovo ThinkPad T480s USB Card Replacement: step 6, image 3 of 3
      • Lift the fan assembly from the system and remove it.
      • Follow our thermal paste application guide before you replace the fan assembly and are ready to reassemble your device.
      Ask FixBot
    1. Lenovo ThinkPad T480s USB Card Replacement, USB Card: step 7, image 1 of 3 Lenovo ThinkPad T480s USB Card Replacement, USB Card: step 7, image 2 of 3 Lenovo ThinkPad T480s USB Card Replacement, USB Card: step 7, image 3 of 3
      • Use a spudger to disconnect the cable from the USB card.
      Ask FixBot
    2. Lenovo ThinkPad T480s USB Card Replacement: step 8, image 1 of 2 Lenovo ThinkPad T480s USB Card Replacement: step 8, image 2 of 2
      • Use the Phillips #1 screwdriver to remove two 3 mm screws from the USB card.
      Ask FixBot
    3. Lenovo ThinkPad T480s USB Card Replacement: step 9, image 1 of 3 Lenovo ThinkPad T480s USB Card Replacement: step 9, image 2 of 3 Lenovo ThinkPad T480s USB Card Replacement: step 9, image 3 of 3
      • With your fingers, lift the USB card from the system.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Sarah Westberg
43,243 Reputation
72 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 103
All Time: 1,739
