Lenovo ThinkPad T480s Motherboard Replacement
    1. Lenovo ThinkPad T480s Motherboard Replacement, Bottom Cover: step 1, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement, Bottom Cover: step 1, image 2 of 2
      • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
      • Loosen the six captive screws with a Phillips #1 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad T480s Motherboard Replacement: step 2, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 2, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 2, image 3 of 3
      • Remove the bottom cover with an opening tool.
      • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
      Ask FixBot
    3. Lenovo ThinkPad T480s Motherboard Replacement: step 3, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement: step 3, image 2 of 2
      • Lift the bottom cover off.
      Ask FixBot
    1. Lenovo ThinkPad T480s Motherboard Replacement, Battery: step 4, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement, Battery: step 4, image 2 of 2
      • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
      Ask FixBot
    2. Lenovo ThinkPad T480s Motherboard Replacement: step 5, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 5, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 5, image 3 of 3
      • Lift the battery near the connector and remove it from the system.
      Ask FixBot
    1. Lenovo ThinkPad T480s Motherboard Replacement, Keyboard: step 6, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement, Keyboard: step 6, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement, Keyboard: step 6, image 3 of 3
      • Disable the battery, power down, and unplug your device before you begin.
      • Pry the left and right trackpad buttons up with a spudger.
      Ask FixBot
    2. Lenovo ThinkPad T480s Motherboard Replacement: step 7, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement: step 7, image 2 of 2
      • With a Phillips #0 screwdriver, loosen the two captive screws underneath the left and right trackpad buttons.
      Ask FixBot
    3. Lenovo ThinkPad T480s Motherboard Replacement: step 8, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 8, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 8, image 3 of 3
      • Wedge the spudger under the front edge of the keyboard to push the keyboard toward the back of the system.
      • Lift the front edge of the keyboard up by a few millimeters.
      Ask FixBot
    4. Lenovo ThinkPad T480s Motherboard Replacement: step 9, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement: step 9, image 2 of 2
      • Gently, pull the keyboard out from the bezel and flip it over.
      • It is connected to the keyboard and trackpad cables so be sure not to yank it over to avoid tearing them.
      Ask FixBot
    5. Lenovo ThinkPad T480s Motherboard Replacement: step 10, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 10, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 10, image 3 of 3
      • Use the spudger to disconnect the trackpad cable from the system.
      • For more information on types of connectors, check out this guide.
      Ask FixBot
    6. Lenovo ThinkPad T480s Motherboard Replacement: step 11, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 11, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 11, image 3 of 3
      • Use the spudger to disconnect the keyboard cable from the system.
      Ask FixBot
    7. Lenovo ThinkPad T480s Motherboard Replacement: step 12, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement: step 12, image 2 of 2
      • Lift the keyboard off of the palm rest.
      Ask FixBot
    1. Lenovo ThinkPad T480s Motherboard Replacement, SSD: step 13, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement, SSD: step 13, image 2 of 2
      • Use the Phillips #1 screwdriver to remove one 2.8 mm screw securing the SSD.
      Ask FixBot
    2. Lenovo ThinkPad T480s Motherboard Replacement: step 14, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 14, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 14, image 3 of 3
      • Pull the SSD out of the socket.
      Ask FixBot
    1. Lenovo ThinkPad T480s Motherboard Replacement, RAM: step 15, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement, RAM: step 15, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement, RAM: step 15, image 3 of 3
      • Pull the plastic film back.
      • Push the clips outward to release the RAM stick.
      • My device doesn't have RAM so you don't see it.
      • The RAM stick will pop out at an angle. Pull the RAM stick out at the same angle.
      Ask FixBot
    1. Lenovo ThinkPad T480s Motherboard Replacement, Wi-Fi Card: step 16, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement, Wi-Fi Card: step 16, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement, Wi-Fi Card: step 16, image 3 of 3
      • Using the nylon spudger, pop the coaxial antenna wires off the Wi-Fi card.
      • When reassembling, reattach the gray wire closest to the screw and the black wire on the other side of the gray wire.
      Ask FixBot
    2. Lenovo ThinkPad T480s Motherboard Replacement: step 17, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement: step 17, image 2 of 2
      • Use the Phillips #1 screwdriver to remove one 2.8mm screw holding the Wi-Fi card down to the motherboard.
      Ask FixBot
    3. Lenovo ThinkPad T480s Motherboard Replacement: step 18, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 18, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 18, image 3 of 3
      • Slide the Wi-Fi card out from the slot.
      Ask FixBot
    1. Lenovo ThinkPad T480s Motherboard Replacement, WWAN Card: step 19, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement, WWAN Card: step 19, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement, WWAN Card: step 19, image 3 of 3
      • Flip the cardboard cover off of the WWAN card.
      • Using the spudger, release the coaxial antenna wires from the WWAN card.
      • When reassembling, reattach the blue wire on the left and the orange wire on the right.
      Ask FixBot
    2. Lenovo ThinkPad T480s Motherboard Replacement: step 20, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement: step 20, image 2 of 2
      • Use a Phillips #1 screwdriver to remove one 2.8mm screw.
      Ask FixBot
    3. Lenovo ThinkPad T480s Motherboard Replacement: step 21, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 21, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 21, image 3 of 3
      • Slide the WWAN card out from the slot.
      Ask FixBot
    1. Lenovo ThinkPad T480s Motherboard Replacement, Fan Assembly: step 22, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement, Fan Assembly: step 22, image 2 of 2
      • Use the spudger to disconnect the fan cable from the motherboard.
      Ask FixBot
    2. Lenovo ThinkPad T480s Motherboard Replacement: step 23, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement: step 23, image 2 of 2
      • Loosen the four captive screws attaching the fan assembly to the motherboard.
      • Do not attempt to remove the captive screws, as forcing them out may strip or damage them.
      Ask FixBot
    3. Lenovo ThinkPad T480s Motherboard Replacement: step 24, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 24, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 24, image 3 of 3
      • Lift the fan assembly from the system and remove it.
      • Follow our thermal paste application guide before you replace the fan assembly and are ready to reassemble your device.
      Ask FixBot
    1. Lenovo ThinkPad T480s Motherboard Replacement, SIM Card Tray: step 25, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement, SIM Card Tray: step 25, image 2 of 2
      • Insert the SIM eject bit or a paper clip in the hole of the SIM tray to eject it.
      • Remove the SIM tray.
      Ask FixBot
    1. Lenovo ThinkPad T480s Motherboard Replacement, Motherboard: step 26, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement, Motherboard: step 26, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement, Motherboard: step 26, image 3 of 3
      • Use the spudger to disconnect the LCD cable from the motherboard.
      Ask FixBot
    2. Lenovo ThinkPad T480s Motherboard Replacement: step 27, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 27, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 27, image 3 of 3
      • Use the spudger to disconnect the camera cable from the motherboard.
      Ask FixBot
    3. Lenovo ThinkPad T480s Motherboard Replacement: step 28, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 28, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 28, image 3 of 3
      • Remove all antenna cables from their routing.
      Ask FixBot
    4. Lenovo ThinkPad T480s Motherboard Replacement: step 29, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 29, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 29, image 3 of 3
      • Use the spudger to disconnect the SD card reader/audio card cable from the board.
      • The cable is attached to the board with adhesive so you will need to peel the cable up.
      Ask FixBot
    5. Lenovo ThinkPad T480s Motherboard Replacement: step 30, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 30, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 30, image 3 of 3
      • Use a connector puller or spudger to disconnect the coin cell battery from the board and pull the cable from the notch.
      Ask FixBot
    6. Lenovo ThinkPad T480s Motherboard Replacement: step 31, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 31, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 31, image 3 of 3
      • Use the spudger to disconnect the trackpad cable, the Hall sensor cable, and the smart card reader cable from the motherboard.
      Ask FixBot
    7. Lenovo ThinkPad T480s Motherboard Replacement: step 32, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 32, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 32, image 3 of 3
      • Disconnect the USB Card cable from the motherboard using the spudger.
      Ask FixBot
    8. Lenovo ThinkPad T480s Motherboard Replacement: step 33, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement: step 33, image 2 of 2
      • Use the spudger to disconnect the power button cable from the motherboard.
      Ask FixBot
    9. Lenovo ThinkPad T480s Motherboard Replacement: step 34, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement: step 34, image 2 of 2
      • Use the Phillips #1 screwdriver to remove the 4.6 mm screw from the USB-C bracket.
      Ask FixBot
    10. Lenovo ThinkPad T480s Motherboard Replacement: step 35, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement: step 35, image 2 of 2
      • Lift the USB-C bracket from the system.
      Ask FixBot
    11. Lenovo ThinkPad T480s Motherboard Replacement: step 36, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement: step 36, image 2 of 2
      • Use the Phillips #1 screwdriver to remove the 4.7 mm screw from the trap door.
      Ask FixBot
    12. Lenovo ThinkPad T480s Motherboard Replacement: step 37, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement: step 37, image 2 of 2
      • Lift the trap door out.
      Ask FixBot
    13. Lenovo ThinkPad T480s Motherboard Replacement: step 38, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement: step 38, image 2 of 2
      • Remove the 4.4 mm screw from the HDMI bracket using the Phillips #1 screwdriver.
      Ask FixBot
    14. Lenovo ThinkPad T480s Motherboard Replacement: step 39, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 39, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 39, image 3 of 3
      • Remove the HDMI bracket from the motherboard using your fingers.
      Ask FixBot
    15. Lenovo ThinkPad T480s Motherboard Replacement: step 40, image 1 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 40, image 2 of 3 Lenovo ThinkPad T480s Motherboard Replacement: step 40, image 3 of 3
      • Using the Phillips #1 screwdriver, remove four 3.1 mm screws from the motherboard.
      Ask FixBot
    16. Lenovo ThinkPad T480s Motherboard Replacement: step 41, image 1 of 2 Lenovo ThinkPad T480s Motherboard Replacement: step 41, image 2 of 2
      • Lift the motherboard from the chassis to remove it from the device.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
3 other people completed this guide.
Sarah Westberg
41,851 Reputation
72 Guides authored
iFixit Member of iFixit
Staff
123 Members
81,372 Guides authored
2 Guide Comments
You saved my life !
Beautiful work, complete, very precise, easy to understand.
Bravo and thank you so much !!!!!!
Keep going this beautiful and so helpful work.
Best!
Louis-Philippe Fourez - Reply Share
Hi @louisphilip8751, thanks for the kind feedback! We're glad the guide helped you successfully complete your repair. Appreciate you taking the time to let us know!
Sarah Westberg - Reply Share
Past 24 Hours: 6
Past 7 Days: 45
Past 30 Days: 235
All Time: 8,258
