Lenovo ThinkPad T480s LCD Panel Replacement
Views: 11K
View statistics:
Past 24 Hours:
7
Past 7 Days:
56
Past 30 Days:
253
All Time:
11,392
Comments: 10
5 comments on steps, 5 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the display panel on your Lenovo ThinkPad T480s laptop.
The display panel, also known as a screen, is the component that outputs visual information from a computer.
Some signs your display panel may be faulty include a blank or black screen, flickering, no backlight, or horizontal or vertical lines. A display panel replacement may be needed if it is cracked or physically damaged. Before attempting a display panel replacement, you may be able to resolve the issue using Lenovo’s troubleshooting guide.
Before replacing your display panel, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
Tools
    1. Lenovo ThinkPad T480s LCD Panel Replacement, Bottom Cover: step 1, image 1 of 2 Lenovo ThinkPad T480s LCD Panel Replacement, Bottom Cover: step 1, image 2 of 2
      • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
      • Loosen the six captive screws with a Phillips #1 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad T480s LCD Panel Replacement: step 2, image 1 of 3 Lenovo ThinkPad T480s LCD Panel Replacement: step 2, image 2 of 3 Lenovo ThinkPad T480s LCD Panel Replacement: step 2, image 3 of 3
      • Remove the bottom cover with an opening tool.
      • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
      Ask FixBot
    3. Lenovo ThinkPad T480s LCD Panel Replacement: step 3, image 1 of 2 Lenovo ThinkPad T480s LCD Panel Replacement: step 3, image 2 of 2
      • Lift the bottom cover off.
      Ask FixBot
    1. Lenovo ThinkPad T480s LCD Panel Replacement, LCD Assembly: step 4, image 1 of 3 Lenovo ThinkPad T480s LCD Panel Replacement, LCD Assembly: step 4, image 2 of 3 Lenovo ThinkPad T480s LCD Panel Replacement, LCD Assembly: step 4, image 3 of 3
      • Use the spudger to disconnect the coaxial cables from the Wi-Fi card and WWAN card.
      • When reassembling the Wi-Fi card, reattach the black wire closest to the screw and the gray wire on the other side of the black wire. With the WWAN card, reattach the blue wire on the left and the orange wire on the right.
      • There are also small color coded arrows on each card that match the corresponding wires, to make sure you connect to the correct spot.
      Ask FixBot
    2. Lenovo ThinkPad T480s LCD Panel Replacement: step 5, image 1 of 3 Lenovo ThinkPad T480s LCD Panel Replacement: step 5, image 2 of 3 Lenovo ThinkPad T480s LCD Panel Replacement: step 5, image 3 of 3
      • Use the spudger to disconnect the LCD cable from the motherboard.
      Ask FixBot
    3. Lenovo ThinkPad T480s LCD Panel Replacement: step 6, image 1 of 3 Lenovo ThinkPad T480s LCD Panel Replacement: step 6, image 2 of 3 Lenovo ThinkPad T480s LCD Panel Replacement: step 6, image 3 of 3
      • Disconnect the camera cable from the motherboard using a spudger.
      Ask FixBot
    4. Lenovo ThinkPad T480s LCD Panel Replacement: step 7, image 1 of 2 Lenovo ThinkPad T480s LCD Panel Replacement: step 7, image 2 of 2
      • Remove all antenna cables from their routing.
      Ask FixBot
    5. Lenovo ThinkPad T480s LCD Panel Replacement: step 8, image 1 of 3 Lenovo ThinkPad T480s LCD Panel Replacement: step 8, image 2 of 3 Lenovo ThinkPad T480s LCD Panel Replacement: step 8, image 3 of 3
      • Using the Phillips #1 screwdriver, remove three 5 mm screws from the left hinge and three 5 mm screws from the right hinge.
      Ask FixBot
    6. Lenovo ThinkPad T480s LCD Panel Replacement: step 9, image 1 of 3 Lenovo ThinkPad T480s LCD Panel Replacement: step 9, image 2 of 3 Lenovo ThinkPad T480s LCD Panel Replacement: step 9, image 3 of 3
      • Carefully rotate the hinges upward and remove the bottom of the machine from the LCD unit.
      Ask FixBot
    1. Lenovo ThinkPad T480s LCD Panel Replacement, LCD Bezel: step 10, image 1 of 3 Lenovo ThinkPad T480s LCD Panel Replacement, LCD Bezel: step 10, image 2 of 3 Lenovo ThinkPad T480s LCD Panel Replacement, LCD Bezel: step 10, image 3 of 3
      • Using the spudger, pry the LCD bezel up from the edges starting near the hinges.
      • It is attached by adhesive so be careful not to break it. You may hear loud snaps when detaching the clips; this is normal.
      Ask FixBot
    2. Lenovo ThinkPad T480s LCD Panel Replacement: step 11, image 1 of 3 Lenovo ThinkPad T480s LCD Panel Replacement: step 11, image 2 of 3 Lenovo ThinkPad T480s LCD Panel Replacement: step 11, image 3 of 3
      • Use the spudger to remove the internal bezel.
      • Start at the corner by the hinge and lift the edge of the internal bezel up with the pointed end of the spudger.
      • Hold the internal bezel with your fingers and work your way around the perimeter of the screen carefully pulling the bezel up.
      • You will feel resistance and hear snapping as you remove the bezel because it is connected with clips. Be careful that you don't crack the bezel. The plastic is delicate in places.
      Ask FixBot
    1. Lenovo ThinkPad T480s LCD Panel Replacement, LCD Panel: step 12, image 1 of 2 Lenovo ThinkPad T480s LCD Panel Replacement, LCD Panel: step 12, image 2 of 2
      • Remove four 2.9 mm screws from the LCD panel using the Phillips #1 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad T480s LCD Panel Replacement: step 13, image 1 of 3 Lenovo ThinkPad T480s LCD Panel Replacement: step 13, image 2 of 3 Lenovo ThinkPad T480s LCD Panel Replacement: step 13, image 3 of 3
      • Gently lift the panel and flip it over.
      • The panel is still connected to the unit by the LCD cable, so be careful not to rip the connector when flipping it over.
      Ask FixBot
    3. Lenovo ThinkPad T480s LCD Panel Replacement: step 14, image 1 of 2 Lenovo ThinkPad T480s LCD Panel Replacement: step 14, image 2 of 2
      • Peel back the tape covering the LCD cable connector.
      • Use the spudger to unlock the LCD cable.
      Ask FixBot
    4. Lenovo ThinkPad T480s LCD Panel Replacement: step 15, image 1 of 2 Lenovo ThinkPad T480s LCD Panel Replacement: step 15, image 2 of 2
      • Remove the LCD cable from the socket.
      Ask FixBot
    5. Lenovo ThinkPad T480s LCD Panel Replacement: step 16, image 1 of 2 Lenovo ThinkPad T480s LCD Panel Replacement: step 16, image 2 of 2
      • Remove the LCD panel from the system.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
5 other people completed this guide.
Sarah Westberg
43,295 Reputation
72 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
5 Guide Comments
Hello, just wondering about step 4.
The description does not match what the image is showing for the Wi-Fi card wiring. The image is showing the black wire being closest to the screw (bottom) and the grey wire being on the opposite side (top). The description describes the opposite which is correct. The correct wiring can be seen in step 3 when the lid has been opened.
Kromagnon - Reply Share
Hi Kromagnon, thanks for pointing this out! I believe when I opened up the device, (which was likely used ), the Wi-Fi card cables were inadvertently switched (as shown in Step 3). I wrote my instructions based on how they were initially connected, but when reassembling I put the cables back correctly and missed the fact that the instructions were inconsistent. Step 4 is now correct. Thanks again!
Sarah Westberg - Reply Share
Why even remove the Wifi cables? Do they actually get in the way of the replacement? I have done this before and don't think that they do.
Nathan Morris - Reply Share
Hi Nathan, thanks for your question. It looks like the Wi-Fi cables are connected to the display assembly, so they will need to be disconnected from the Wi-Fi card prior to removing the display.
On (the nominal printed page of 69 or) page 75 of the PDF file of Lenovo's official service guide, the writing states:
- The gray cable goes to MAIN or 2 of the Wireless LAN (Wi-Fi) card, and
- The black cable goes to AUX or 1 of the WLAN card.
This means the correct cable position is supposed to be:
- Gray is below, nearest the retaining screw; and
- Black is above.
So, currently the photos showing how to connect in Step 3 are correct and the photos in Step 4 are incorrect.
You can see in this video (timestamped) from MobileTechReview. This shows the T480s during 2018, the year of its release. So, this shows how the Wi-Fi antenna cables should be attached, as assembled from the factory for the OEM WLAN card.
Tai Lam - Reply Share
Past 24 Hours: 7
Past 7 Days: 56
Past 30 Days: 253
All Time: 11,392
