Lenovo ThinkPad T480s Hinges Replacement
    1. Lenovo ThinkPad T480s Hinges Replacement, Bottom Cover: step 1, image 1 of 2 Lenovo ThinkPad T480s Hinges Replacement, Bottom Cover: step 1, image 2 of 2
      • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
      • Loosen the six captive screws with a Phillips #1 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad T480s Hinges Replacement: step 2, image 1 of 3 Lenovo ThinkPad T480s Hinges Replacement: step 2, image 2 of 3 Lenovo ThinkPad T480s Hinges Replacement: step 2, image 3 of 3
      • Remove the bottom cover with an opening tool.
      • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
      Ask FixBot
    3. Lenovo ThinkPad T480s Hinges Replacement: step 3, image 1 of 2 Lenovo ThinkPad T480s Hinges Replacement: step 3, image 2 of 2
      • Lift the bottom cover off.
      Ask FixBot
    1. Lenovo ThinkPad T480s Hinges Replacement, LCD Assembly: step 4, image 1 of 3 Lenovo ThinkPad T480s Hinges Replacement, LCD Assembly: step 4, image 2 of 3 Lenovo ThinkPad T480s Hinges Replacement, LCD Assembly: step 4, image 3 of 3
      • Use the spudger to disconnect the coaxial cables from the Wi-Fi card and WWAN card.
      • When reassembling the Wi-Fi card, reattach the black wire closest to the screw and the gray wire on the other side of the black wire. With the WWAN card, reattach the blue wire on the left and the orange wire on the right.
      • There are also small color coded arrows on each card that match the corresponding wires, to make sure you connect to the correct spot.
      Ask FixBot
    2. Lenovo ThinkPad T480s Hinges Replacement: step 5, image 1 of 3 Lenovo ThinkPad T480s Hinges Replacement: step 5, image 2 of 3 Lenovo ThinkPad T480s Hinges Replacement: step 5, image 3 of 3
      • Use the spudger to disconnect the LCD cable from the motherboard.
      Ask FixBot
    3. Lenovo ThinkPad T480s Hinges Replacement: step 6, image 1 of 3 Lenovo ThinkPad T480s Hinges Replacement: step 6, image 2 of 3 Lenovo ThinkPad T480s Hinges Replacement: step 6, image 3 of 3
      • Disconnect the camera cable from the motherboard using a spudger.
      Ask FixBot
    4. Lenovo ThinkPad T480s Hinges Replacement: step 7, image 1 of 2 Lenovo ThinkPad T480s Hinges Replacement: step 7, image 2 of 2
      • Remove all antenna cables from their routing.
      Ask FixBot
    5. Lenovo ThinkPad T480s Hinges Replacement: step 8, image 1 of 3 Lenovo ThinkPad T480s Hinges Replacement: step 8, image 2 of 3 Lenovo ThinkPad T480s Hinges Replacement: step 8, image 3 of 3
      • Using the Phillips #1 screwdriver, remove three 5 mm screws from the left hinge and three 5 mm screws from the right hinge.
      Ask FixBot
    6. Lenovo ThinkPad T480s Hinges Replacement: step 9, image 1 of 3 Lenovo ThinkPad T480s Hinges Replacement: step 9, image 2 of 3 Lenovo ThinkPad T480s Hinges Replacement: step 9, image 3 of 3
      • Carefully rotate the hinges upward and remove the bottom of the machine from the LCD unit.
      Ask FixBot
    1. Lenovo ThinkPad T480s Hinges Replacement, LCD Bezel: step 10, image 1 of 3 Lenovo ThinkPad T480s Hinges Replacement, LCD Bezel: step 10, image 2 of 3 Lenovo ThinkPad T480s Hinges Replacement, LCD Bezel: step 10, image 3 of 3
      • Using the spudger, pry the LCD bezel up from the edges starting near the hinges.
      • It is attached by adhesive so be careful not to break it. You may hear loud snaps when detaching the clips; this is normal.
      Ask FixBot
    2. Lenovo ThinkPad T480s Hinges Replacement: step 11, image 1 of 3 Lenovo ThinkPad T480s Hinges Replacement: step 11, image 2 of 3 Lenovo ThinkPad T480s Hinges Replacement: step 11, image 3 of 3
      • Use the spudger to remove the internal bezel.
      • Start at the corner by the hinge and lift the edge of the internal bezel up with the pointed end of the spudger.
      • Hold the internal bezel with your fingers and work your way around the perimeter of the screen carefully pulling the bezel up.
      • You will feel resistance and hear snapping as you remove the bezel because it is connected with clips. Be careful that you don't crack the bezel. The plastic is delicate in places.
      Ask FixBot
    1. Lenovo ThinkPad T480s Hinges Replacement, LCD Panel: step 12, image 1 of 2 Lenovo ThinkPad T480s Hinges Replacement, LCD Panel: step 12, image 2 of 2
      • Remove four 2.9 mm screws from the LCD panel using the Phillips #1 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad T480s Hinges Replacement: step 13, image 1 of 3 Lenovo ThinkPad T480s Hinges Replacement: step 13, image 2 of 3 Lenovo ThinkPad T480s Hinges Replacement: step 13, image 3 of 3
      • Gently lift the panel and flip it over.
      • The panel is still connected to the unit by the LCD cable, so be careful not to rip the connector when flipping it over.
      Ask FixBot
    3. Lenovo ThinkPad T480s Hinges Replacement: step 14, image 1 of 2 Lenovo ThinkPad T480s Hinges Replacement: step 14, image 2 of 2
      • Peel back the tape covering the LCD cable connector.
      • Use the spudger to unlock the LCD cable.
      Ask FixBot
    4. Lenovo ThinkPad T480s Hinges Replacement: step 15, image 1 of 2 Lenovo ThinkPad T480s Hinges Replacement: step 15, image 2 of 2
      • Remove the LCD cable from the socket.
      Ask FixBot
    5. Lenovo ThinkPad T480s Hinges Replacement: step 16, image 1 of 2 Lenovo ThinkPad T480s Hinges Replacement: step 16, image 2 of 2
      • Remove the LCD panel from the system.
      Ask FixBot
    1. Lenovo ThinkPad T480s Hinges Replacement, Hinges: step 17, image 1 of 2 Lenovo ThinkPad T480s Hinges Replacement, Hinges: step 17, image 2 of 2
      • Use the Phillips #1 screwdriver to remove two 2.8 mm screws from the hinge in the upper right corner.
      Ask FixBot
    2. Lenovo ThinkPad T480s Hinges Replacement: step 18, image 1 of 2 Lenovo ThinkPad T480s Hinges Replacement: step 18, image 2 of 2
      • Remove the hinge in the upper right corner.
      Ask FixBot
    3. Lenovo ThinkPad T480s Hinges Replacement: step 19, image 1 of 2 Lenovo ThinkPad T480s Hinges Replacement: step 19, image 2 of 2
      • Use a Phillips #1 screwdriver to remove two 2.8 mm screws from the hinge in the upper left corner.
      Ask FixBot
    4. Lenovo ThinkPad T480s Hinges Replacement: step 20, image 1 of 2 Lenovo ThinkPad T480s Hinges Replacement: step 20, image 2 of 2
      • Remove the hinge in the upper left corner.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Sarah Westberg
41,848 Reputation
72 Guides authored
iFixit Member of iFixit
Staff
123 Members
79,097 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 66
All Time: 2,032
