Lenovo ThinkPad T480s Hall Sensor Replacement
Views: 5.4K
View statistics:
Past 24 Hours:
7
Past 7 Days:
46
Past 30 Days:
153
All Time:
5,351
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the Hall sensor in a Lenovo ThinkPad T480s laptop.
The Hall sensor is used in laptops that don’t have a mechanical latch. It can tell if your laptop is closed or not. If the Hall sensor is not working, it may not tell the system to turn off when the screen is closed. If your Hall sensor fails due to corrosion, cracks, or breakage, you may need to replace it. Prior to beginning the repair, check out the Lenovo Troubleshooting page.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Parts
Tools
    1. Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: step 1, image 1 of 2 Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: step 1, image 2 of 2
      • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
      • Loosen the six captive screws with a Phillips #1 screwdriver.
      Ask FixBot
    2. Lenovo ThinkPad T480s Hall Sensor Replacement: step 2, image 1 of 3 Lenovo ThinkPad T480s Hall Sensor Replacement: step 2, image 2 of 3 Lenovo ThinkPad T480s Hall Sensor Replacement: step 2, image 3 of 3
      • Remove the bottom cover with an opening tool.
      • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
      Ask FixBot
    3. Lenovo ThinkPad T480s Hall Sensor Replacement: step 3, image 1 of 2 Lenovo ThinkPad T480s Hall Sensor Replacement: step 3, image 2 of 2
      • Lift the bottom cover off.
      Ask FixBot
    1. Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: step 4, image 1 of 2 Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: step 4, image 2 of 2
      • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
      Ask FixBot
    2. Lenovo ThinkPad T480s Hall Sensor Replacement: step 5, image 1 of 3 Lenovo ThinkPad T480s Hall Sensor Replacement: step 5, image 2 of 3 Lenovo ThinkPad T480s Hall Sensor Replacement: step 5, image 3 of 3
      • Lift the battery near the connector and remove it from the system.
      Ask FixBot
    1. Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: step 6, image 1 of 3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: step 6, image 2 of 3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: step 6, image 3 of 3
      • Use a spudger to disconnect the cable from the Hall sensor.
      Ask FixBot
    2. Lenovo ThinkPad T480s Hall Sensor Replacement: step 7, image 1 of 2 Lenovo ThinkPad T480s Hall Sensor Replacement: step 7, image 2 of 2
      • With the Phillips #1 screwdriver, remove one 3.1 mm screw from the sensor.
      Ask FixBot
    3. Lenovo ThinkPad T480s Hall Sensor Replacement: step 8, image 1 of 3 Lenovo ThinkPad T480s Hall Sensor Replacement: step 8, image 2 of 3 Lenovo ThinkPad T480s Hall Sensor Replacement: step 8, image 3 of 3
      • Remove the sensor from the system.
      Ask FixBot
Sarah Westberg
43,283 Reputation
72 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 46
Past 30 Days: 153
All Time: 5,351
