Introduction
The Wi-Fi card communicates with your wireless network through the router. If it is in range, your laptop will be able to connect to the internet if it's not password protected. If your Wi-Fi card is failing, follow this guide to replace your Lenovo ThinkPad T480 Wi-Fi Card.
The main symptom of a failing Wi-Fi card is problems with connectivity—more specifically failure to locate wireless connections, intermittent wireless connections and loss of connectivity due to hardware damage.
Prior to beginning this guide, be sure to disable the internal battery, power off the device, and unplug the laptop from the charging cable.
Use a Phillips #1 screwdriver to remove the two 4.6 mm screws that secure the internal battery to the frame.
Using the Phillips #1 screwdriver, remove the single 3.6 mm screw at the top of the Wi-Fi card attaching it to the motherboard.
4 other people completed this guide.
4 Guide Comments
Great guide! Everyone make sure to reconnect the black cable to terminal 2 (on the left) and white to t1 (to the right).
Step 9 only worked for one of the antennaes so had to abort as they fragile, please provide an alternative method if the connector wont pop out with this method. Also a reassembly guide should be part of this, especially on how to reattach the connectors?
Hi @chrisbloggs, Thanks for your comment! ******I updated Step 9 to include a bit more detail. If you’re unable to disconnect the other cable, you might consider using an antenna disconnect tool—it's designed specifically for that task. In most cases, a spudger or tweezers will work, but the tool can be a useful alternative. Good luck with your repair!
