Introduction
If you need to replace the palmrest of your ThinkPad T480, read this guide.
As someone who has used ifixit for many years, I feel like i should contribute.
I have done tons of work on my thinkpad, and looking at the t480 page, i realized nobody had done a guide on replacing this.
so here we are :3
Use the Phillips #1 screwdriver to loosen the two screws parallel to the battery compartment.
Use a Phillips #1 screwdriver to remove the two 4.6 mm screws that secure the internal battery to the frame.
Using the Phillips #1 screwdriver remove the four 3.1 mm screws from the chassis.
Using the Phillips #1 screwdriver, remove two 4.8 mm screws from the right speaker.
Using the black nylon spudger, lift the connector lock up.
Disconnect the storage cable from the system board.
Using the Phillips #1 screwdriver, remove three 4.6 mm screws from the I/O bracket.
Use the black nylon spudger to lift up the small locking flap on the power button cable's ZIF connector.
Slide the power button cable out of the ZIF connector.
Remove the trackpad ribbon from the old palm rest and move it to the same spot on the new one. Pull it up carefully and glue it down or use kapton tape.
To reassemble your device, follow these instructions in reverse order. If I missed anything, Please feel free to update my guide.
Things to remember during reassembly
Make sure to put everything back in the new palm rest, not the old one. (I made that mistake)
When reattaching the fan, please reapply thermal paste: follow this guide.
When putting the trackpad back in, make sure to center it before fully screwing it in.
Good luck, take your time, and don't break any connectors off of the motherboard.
2 other people completed this guide.
