Lenovo ThinkPad T480 Keyboard Replacement
    1. Lenovo ThinkPad T480 Keyboard Replacement, External Battery: step 1, image 1 of 2 Lenovo ThinkPad T480 Keyboard Replacement, External Battery: step 1, image 2 of 2
      • Disable the battery, power down, and unplug your device before you begin.
      • Flip the laptop over so the bottom of the device is showing.
      Ask FixBot
    2. Lenovo ThinkPad T480 Keyboard Replacement: step 2, image 1 of 3 Lenovo ThinkPad T480 Keyboard Replacement: step 2, image 2 of 3 Lenovo ThinkPad T480 Keyboard Replacement: step 2, image 3 of 3
      • Using your fingers, slide the lock on each side of the battery to the unlocked position.
      • Remove the battery from the slot.
      Ask FixBot
    1. Lenovo ThinkPad T480 Keyboard Replacement, Keyboard: step 3, image 1 of 1
      • Use the Phillips #1 screwdriver to loosen the two screws parallel to the battery compartment.
      Ask FixBot
    2. Lenovo ThinkPad T480 Keyboard Replacement: step 4, image 1 of 1
      • Open the laptop so the keyboard is facing you.
      Ask FixBot
    3. Lenovo ThinkPad T480 Keyboard Replacement: step 5, image 1 of 3 Lenovo ThinkPad T480 Keyboard Replacement: step 5, image 2 of 3 Lenovo ThinkPad T480 Keyboard Replacement: step 5, image 3 of 3
      • Push the keyboard towards the screen and away from the trackpad and then slide it out towards you gently.
      • The keyboard is connected to the board by two ribbon connectors.
      • Be careful not to rip the connectors when you flip the keyboard over.
      Ask FixBot
    4. Lenovo ThinkPad T480 Keyboard Replacement: step 6, image 1 of 3 Lenovo ThinkPad T480 Keyboard Replacement: step 6, image 2 of 3 Lenovo ThinkPad T480 Keyboard Replacement: step 6, image 3 of 3
      • Flip the keyboard over towards you to expose the backside of the keyboard and the two ribbon connectors.
      • Using the black nylon spudger, flip the first ribbon connector lock open. Slide the first connector out.
      Ask FixBot
    5. Lenovo ThinkPad T480 Keyboard Replacement: step 7, image 1 of 3 Lenovo ThinkPad T480 Keyboard Replacement: step 7, image 2 of 3 Lenovo ThinkPad T480 Keyboard Replacement: step 7, image 3 of 3
      • Using the black nylon spudger, unlock the second ribbon connector and slide it out from the port.
      Ask FixBot
    6. Lenovo ThinkPad T480 Keyboard Replacement: step 8, image 1 of 2 Lenovo ThinkPad T480 Keyboard Replacement: step 8, image 2 of 2
      • Remove the keyboard from the laptop.
      Ask FixBot
16 other people completed this guide.
Sarah Westberg
43,243 Reputation
72 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
3 Guide Comments
Thanks for this. I need help with my Lenovo Thinkpad T480 keyboard to motherboard connector pin. That is the third image in step 6.
Where can I get a replacement?
EagleCreeks Assortment - Reply Share
Thank you so much!
Lioneed Devotchenko - Reply Share
Hi @lioneeddev99026, You are most welcome. I'm glad the guide was helpful!
Sarah Westberg - Reply Share
Past 24 Hours: 13
Past 7 Days: 180
Past 30 Days: 703
All Time: 29,752
