Lenovo ThinkPad T480 Hard Drive Replacement
    1. Lenovo ThinkPad T480 Hard Drive Replacement, External Battery: step 1, image 1 of 2 Lenovo ThinkPad T480 Hard Drive Replacement, External Battery: step 1, image 2 of 2
      • Disable the battery, power down, and unplug your device before you begin.
      • Flip the laptop over so the bottom of the device is showing.
      Ask FixBot
    2. Lenovo ThinkPad T480 Hard Drive Replacement: step 2, image 1 of 3 Lenovo ThinkPad T480 Hard Drive Replacement: step 2, image 2 of 3 Lenovo ThinkPad T480 Hard Drive Replacement: step 2, image 3 of 3
      • Using your fingers, slide the lock on each side of the battery to the unlocked position.
      • Remove the battery from the slot.
      Ask FixBot
    1. Lenovo ThinkPad T480 Hard Drive Replacement, Back Cover: step 3, image 1 of 2 Lenovo ThinkPad T480 Hard Drive Replacement, Back Cover: step 3, image 2 of 2
      • Using the Phillips #1 screwdriver, loosen the six captive screws.
      Ask FixBot
    2. Lenovo ThinkPad T480 Hard Drive Replacement: step 4, image 1 of 3 Lenovo ThinkPad T480 Hard Drive Replacement: step 4, image 2 of 3 Lenovo ThinkPad T480 Hard Drive Replacement: step 4, image 3 of 3
      • Insert the blue plastic opening tool into the space between the lower case and the chassis.
      • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
      • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
      • Remove the back case.
      Ask FixBot
    1. Lenovo ThinkPad T480 Hard Drive Replacement, Remove the battery: step 5, image 1 of 2 Lenovo ThinkPad T480 Hard Drive Replacement, Remove the battery: step 5, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the two 4.6 mm screws that secure the internal battery to the frame.
      • Not All T480 laptops come with an internal battery. If there is a spacer or nothing here, skip the next two steps.
      Ask FixBot
    2. Lenovo ThinkPad T480 Hard Drive Replacement: step 6, image 1 of 3 Lenovo ThinkPad T480 Hard Drive Replacement: step 6, image 2 of 3 Lenovo ThinkPad T480 Hard Drive Replacement: step 6, image 3 of 3
      • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
      Ask FixBot
    3. Lenovo ThinkPad T480 Hard Drive Replacement: step 7, image 1 of 2 Lenovo ThinkPad T480 Hard Drive Replacement: step 7, image 2 of 2
      • Lift the battery straight out of its recess and remove it.
      • If the battery is difficult to remove from the recess, use a nylon spudger to gently lift it on one edge, making it easier to grasp and remove by hand.
      • To prevent damage or potential fire, do not bend or flex the battery. Only use a plastic spudger and avoid any sharp tools that could puncture the battery.
      Ask FixBot
    1. Lenovo ThinkPad T480 Hard Drive Replacement, Hard Drive: step 8, image 1 of 3 Lenovo ThinkPad T480 Hard Drive Replacement, Hard Drive: step 8, image 2 of 3 Lenovo ThinkPad T480 Hard Drive Replacement, Hard Drive: step 8, image 3 of 3
      • Using the black nylon spudger, lift the connector lock up.
      • Disconnect the storage cable from the motherboard.
      Ask FixBot
    2. Lenovo ThinkPad T480 Hard Drive Replacement: step 9, image 1 of 3 Lenovo ThinkPad T480 Hard Drive Replacement: step 9, image 2 of 3 Lenovo ThinkPad T480 Hard Drive Replacement: step 9, image 3 of 3
      • Lift the hard drive up with a tab if it has one or with your spudger.
      • Lift the drive assembly from the system.
      Ask FixBot
    3. Lenovo ThinkPad T480 Hard Drive Replacement: step 10, image 1 of 3 Lenovo ThinkPad T480 Hard Drive Replacement: step 10, image 2 of 3 Lenovo ThinkPad T480 Hard Drive Replacement: step 10, image 3 of 3
      • Pull the plastic drive bracket outward to remove it from the hard drive.
      Ask FixBot
    4. Lenovo ThinkPad T480 Hard Drive Replacement: step 11, image 1 of 2 Lenovo ThinkPad T480 Hard Drive Replacement: step 11, image 2 of 2
      • Flip it over and remove the drive connector from the assembly.
      Ask FixBot
9 other people completed this guide.
Sarah Westberg
41,848 Reputation
72 Guides authored
iFixit Member of iFixit
Staff
123 Members
80,724 Guides authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 84
Past 30 Days: 399
All Time: 35,809
